What is this?? (34611-B Hose)
Do you see the NIPPLE on the first picture on the right hand side of the pumpkin. This is the breather for the axle so water will not get into your differential. Put a clamp on the hose and re-attach it to the open nipple on the right hand side that is on pic 1 and you will be OK.
Hope this makes sense tried to make it as simple as possible
What about the other end of the tube with the white plastic breather nozzle. It appears to have been attached somewhere previously and now is floating in my tire well.
Yeah, that's where the stock ones live; not the best spot & many people extend & relocate their breathers, particularly if they're into watersports or running a lift & doing a little flexing on the rocks. Now might be the time to do the same yourself...
Here's a link to a writeup link with pics that show the breather in question and how to extend the tubes.
https://www.jk-forum.com/forums/show...reather+extend
I would suggest you follow the write up and extend your hose.
How did this happen on both ends. Did you do some serious wheelin, or were you under the messing with things. Just curious.
Perfect!
Thanks Zeppo!
