When getting a 2012 will it be possible to get the following?
Old Jun 16, 2011 | 11:40 AM
Pcgizzmo's Avatar
Default When getting a 2012 will it be possible to get the following?
I'm wanting an Unlimited with
Freedom Tops
Hard Top
Automatic
AC
Standard Radio
I'm adding 2.5 Lift, Wheels. Tires and aftermarket sound system w/blue tooth, GPS and backup camera.
Is there any reason to get one of the packages if this is what I want? If I decide to get leather or power windows can you just get those w/out having to purchase a package and pay for something you don't want?
Thanks....
Old Jun 17, 2011 | 06:42 AM
Pcgizzmo's Avatar
Bumping my own thread.
OK, so maybe if this were a 2011? I believe the options are close to the same. Thanks...
Old Jun 17, 2011 | 06:46 AM
BKGM Jeepers's Avatar
Auto, AC and the Tops are individual options and can be ordered seperately. The radio is usually tied to the trim level you buy. If you order a Non-Sahara or Rubicon, you should come with a fairly basic radio. Those are not too difficult.
When you try for leather seating, or gear ratio changes such as the towing package, you may be required to order other items.
Old Jun 17, 2011 | 06:50 AM
Davep22's Avatar
You may have to go to the dealership to get a full list of stock features/options for the 2012. I believe a radio is in all wranglers and an Auto-transmission is available on all trims of the wrangler. My guess would be that A/C is as well (but the base may not include it). As for the top - if its not available on a basic model, you can always buy just the top when you by the vehicle.
If I were you, i'd make a trip to the dealership and see what they know of the package options vs. what you're looking for - or give them a call if they're a long way away.
Bottom line is that the options your looking for are all relatively basic - I can't image them not being available on most if not all trim packages.
Old Jun 17, 2011 | 07:16 AM
Zroe's Avatar
I think most dealerships would probably carry a configuration like this on the lot. You probably wouldn't have to special order. It would be the X or Sport or whatever they are calling the base model these days. Do try to get the tow package at least, to bump up your gear ratio to 3.73 or 4.1, whatever the 2012's will carry.
Old Jun 17, 2011 | 07:42 AM
donnie's Avatar
From: Simi Valley, Ca., Taylorsville, Ut. and places in between
Something else you could try is go on to the Jeep site.
Under the heading"Build your own", configure it the way you want.
After that is done, it should show a dealer that has what you "built".
Worth a try anyway.
Old Jun 17, 2011 | 09:59 AM
Pcgizzmo's Avatar
Thanks for the input. I appreciate it..
Old Jun 17, 2011 | 11:31 AM
bowerss2's Avatar
from what i understand the 12 will be powered by a small cold fusion device. It will get 11 000 000 000 mpg (of salt water) have 900WHP and actually micro brew beer for its owner.
here is a spy shot of a 12 in action.... as you can see they have made minor tweaks for aerodynamics.
