why is my jk acting like a POS?
Guest
Posts: n/a
Dude!
That looks like the deepest mud / water hole at Rausch Creek along the power lines! Lots of wheeling rigs have hydrolocked in that hole in the summer when it is a foot or so more shallow.
I had my new Rubi there in January and we drove over that hole since it was covered with ice. After seeing your photo, I am steering clear of that obstacle from now on. I hope your dealership's service manager doesn't look at this forum. If he sees that picture, you are screwed!
I hope you get it straightened out without any more hassles!
That looks like the deepest mud / water hole at Rausch Creek along the power lines! Lots of wheeling rigs have hydrolocked in that hole in the summer when it is a foot or so more shallow. I had my new Rubi there in January and we drove over that hole since it was covered with ice. After seeing your photo, I am steering clear of that obstacle from now on. I hope your dealership's service manager doesn't look at this forum. If he sees that picture, you are screwed!
Awsome picture man! No ideas, just love the shot.. I stay away from Ice holes like that now. I have a built cherokee that i ripped the front end out of one year going into shit like that... Bent some stuff, killed a knuckle... Ice and "built" 4x4 not again.
hope you get her fixed!
Hmm .. If its not the MAF, Have you checked spark plugs, plug wires, and coils? I had similiar issues with my Ram and it turned out to be a bad plug wire connection (corrossion/dirt in the brass connector). A bad coil wire would have similiar albeit worse symtoms. A defective/fouled spark plug will also fail under load, causing arcing and produce similiar results. It is possible that Cold water may have cracked the porceline on a spark plug.
SO?!?!?!?!? What happened?????????????????
I sent you a PM, but have almost the exact same symptoms you had. It all started when I broke my evap can, too.
Anybody else?? How can I fix this choking out feeling at higher RPM's?????
he had a sunfire that came in for months that they were replacing injectors and draining the tank and they thought the owner was getting bad gas. but they looked harder and the fill tube had small pinholes from rust and it was enough to let water in the tank. they fixed that and it was fine.
Anywho... Glad I don't have that piece of crap anymore.
I dont really see what you find so "slap funny?" I dont wonder WHY my Jeep was running like hell. I only FUCK up my Jeep by using it for its intended purposes. I might push the limit of its capabilities, but I also dont pass the buck when it comes to blame. I bashed my evap can, and now need a fix... so turned to somebody with a similar experience for some insight on their outcome. WTF? Maybe you werent directing this comment toward me...
