Windshield defroster is a safety hazard
#72
Are there differences in the way they set the thermos in the more northern Jeeps?
#73
It's a head scratcher. The system seems challenged in ice storms in clearing the windshield and wipers. But what the hell - it hones ones skills as a manager of the air flow. My wife said I should let my dad ride with us because he blows enough hot air to melt the glass- I think she was pissed off due to the cat barfing in her shoe that morning.
#74
I've had the same problem today and was thinking about a solution for this. If you could somehow cut the defrost vent slats from the bottom about 3/4 of the way through and then bend the fins outward toward the driver side then perhaps that will deflect enough air to keep that part deiced. If the plastic isn't long enough then you could even glue extentions to them.
I would try this out myself but my tools are 2000 miles away from me right now.
Thanks katsumotology for the pic
#75
Reviving an old thread because, hey, it's ****ing winter in Alaska and once again, the suffering begins with this worthless windshield defroster. The '08 JK has the worst defroster design imaginable. The center 1/3 of the windshield gets the heat, leaving both driver and passenger side frozen or melted just enough to drag snow and ice across your field of vision. And the heat doesn't even come close to defrosting the windshield wipers because the wipers are an inch below where the heat hits the windshield. If you have not experienced this then your weather is NOT bad enough. Designed by a committee of chimpanzees and field tested in Arizona.
#77
This is what I did years ago. I just throw it over the defroster vents in the winter.
It improves the distribution of the hot air.
Attachment 676180
Attachment 676180
#78
It does a much better job of getting the warm air to the ends of the windshield. Defogging on the inside, and deicing on the outside are more effective. I remove it in the summer.
