The “Ultimate Housing” is Like a Mansion for Your Gears
By -
spn68c35t-lcIf you get the Ultimate Unit Bearings from Spidertrax, you can’t skimp on the rear-end housing. Quadratec has you covered by offering the Spidertrax Spider 9 Ultimate Housing that just underwent a redesign. Let’s take a look at the changes to the legendary rear housing.
spn65c35ytic
The Ultimate Housing is constructed with a single piece of quarter-inch-thick shell, 0.375-inch-thick face plate, and 3.5×0.25 wall axle tubes. The face plate is now able to take on both nine-inch and 10-inch gears in the same fashion as the Pro Housing. The redesigned shell features 12-point screw-in studs for ultimate third-member retention. They also improve the looks of the Spider 9 Ultimate Housing while still retaining ultimate strength with tig welding on the outside of the shell, so you get the ultimate in style and construction.
spn68c35t-fcFinally, the Spider 9 Ultimate Housing comes with nearly everything to help make building it quick by including the third-member studs, nylocks, fill bung, and cap. At 68-inches wide, it’s perfect for nearly any off-road application.
Get more information at Quadratec.com.
Chime in with your thoughts on the forum. >>
