Antenna Cable Routing
Old May 24, 2009 | 01:26 PM
mikeyfl's Avatar
Originally Posted by BMPJDS
i made a bracket to hold my cb over the rear view mirror and ran my coax under the roll bar covers straight to the back and through the hole in the tail gate. you would never know it was there unless someone told you. only took me about 15 minutes
what length coax did you use?
Old May 24, 2009 | 01:33 PM
BMPJDS's Avatar
18ft and i had atleast 2 1/2 ft extra
Old May 24, 2009 | 01:52 PM
paramaniac's Avatar
Originally Posted by mikeyfl
if you dont have carpet, where are you running the cable?
my cb lives in my center console... i dont run with carpet in the summer months so i ran the antenna cable under the passenger seat and picked up the wire loom thats under there and zip tied the cable to the loom all the way to the back, then on the cloth limiting strap on the rear gate through the plastic trim piece on top and out a grommet to the teraflex antenna mount.
did that make sense?
Old May 24, 2009 | 02:32 PM
mikeyfl's Avatar
yes.
what is in that wire loom? does it cause any interference with the cb?
Old May 24, 2009 | 02:46 PM
paramaniac's Avatar
I don't know what is in there... As for interference, I only use it when I wheel so its just short range stuff, but I have no problems
Old May 24, 2009 | 05:44 PM
....I ran mine through the plastic hose (Sorry! I don't know the "technical" term!) that holds all the other wires along the passenger side of the vehicle. Then like mentioned above ran it through the tail gate with the third brake light cable. Hope this helps!
Old May 24, 2009 | 06:17 PM
mikeyfl's Avatar
wire loom!
im trying to figure out where to put the cb... i already have something mounted above the rear view, so that spot is no good. im thinking either in the arm rest console or under the steering wheel. since thats the case, im probably going to go through the passenger wire loom.
Old May 24, 2009 | 07:13 PM
bluerubicon08's Avatar
I ran mine up and along the roll bar under the padding/cover. Works great since I mounted my CB over the rear view mirror.
Old May 24, 2009 | 07:15 PM
wire loom!
There was a post on here from someone who mounted it under the steering wheel ............... cut a hole in the plastic fairing there ......looked like a factory install. If you do a search you should be able to find it
Old May 24, 2009 | 07:34 PM
mikeyfl's Avatar
yeah, i was out in the garage and had the piece off. looked here and a couple people have mounted it there.
