Antenna Cable Routing
what length coax did you use?
my cb lives in my center console... i dont run with carpet in the summer months so i ran the antenna cable under the passenger seat and picked up the wire loom thats under there and zip tied the cable to the loom all the way to the back, then on the cloth limiting strap on the rear gate through the plastic trim piece on top and out a grommet to the teraflex antenna mount.
did that make sense?
what is in that wire loom? does it cause any interference with the cb?
....I ran mine through the plastic hose (Sorry! I don't know the "technical" term!) that holds all the other wires along the passenger side of the vehicle. Then like mentioned above ran it through the tail gate with the third brake light cable. Hope this helps!
im trying to figure out where to put the cb... i already have something mounted above the rear view, so that spot is no good. im thinking either in the arm rest console or under the steering wheel. since thats the case, im probably going to go through the passenger wire loom.
wire loom!
yeah, i was out in the garage and had the piece off. looked here and a couple people have mounted it there.
