CB
Old Aug 8, 2012 | 06:52 PM
SinsterJK's Avatar
Default CB
What is a good entry level CB?
Old Aug 8, 2012 | 07:12 PM
thelorax64's Avatar
I've been driving trucks for 30 years have had several CBs from expensive to free... And I've alwAys liked the Cobras the cheep every dirt hole sales them... So when a part fails it isn't hard to find a replacement .... And every CB. Shop knows not only how to fix it but how to soup them up... Hope this is helpful.
Old Aug 9, 2012 | 03:13 AM
Smitty12JKU's Avatar
X2
I also have quite a few and my CB shop at my house. For jeepers I usually recommend Cobra as well as Uniden. The main boards on them are generally the same so looks and features are going to be your deciding factor. Some of the guys on here are running midlands which are also good. Midland makes a unit similar to the Cobra 75 that has some different features.
Old Aug 9, 2012 | 03:27 AM
OH9JK's Avatar
JK-Forum Ambassador
Uniden Pro 520XL
It is a damn fine radio with a small footprint!
Old Aug 9, 2012 | 05:37 AM
SinsterJK's Avatar
Thanks for all the info.
Old Aug 9, 2012 | 04:04 PM
swiz9's Avatar
What are anyones thoughts on 40 channel CB's from Radio Shack. I have one that 10 yrs old that was in my YJ and want to put it in my JK. Should I upgrade? I only need it for some highway use as well as on the trail.
Old Aug 9, 2012 | 04:23 PM
Sahara_Maverick's Avatar
If it was working on your YJ there's no reason it will not work on the JK. I'd save the money for other mods, mostly if you will use it just a little.
Old Aug 9, 2012 | 05:43 PM
Rooster76's Avatar
I did way too much research before I got mine. I have everything you need and the best small tough radio options
here is a direct link->https://www.jk-forum.com/forums/jk-c...7/#post3070835
Your not going to get one that is going to perform much better if at all. Though RF gain is a nice feature to have. The biggest thing that improves your CB range is your antenna set-up because the CB market is limited to a measly 4 watts by the FCC. I think the best antenna you can get would be the 3' or 4' Firestik Firefly(not not all firestiks are firefly's. They will have an FL in the name). It's very flexible and has good performance.
Old Aug 10, 2012 | 07:30 AM
swiz9:
I agree with the other two. If it works, the only reason to swap is features or looks.
Old Aug 10, 2012 | 05:21 PM
CW Spook's Avatar
There has been no real improvements in CB radio since the mid 70s, so if you've got one that works there is no reason, aside from vanity, to change.
