CB Coax for Cobra 75
Old Sep 1, 2012 | 10:43 AM
renzo1200's Avatar
Default CB Coax for Cobra 75
Can anyone recommend which coaxial cable I need to run in my Wrangler.
I've got the Cobra 75 with a Teraflex tailgate mount.
Tx much
-G
Old Sep 1, 2012 | 11:22 AM
951JEEP's Avatar
RG-58U. this is what i have with the same CB. 18' RG-58U CB RADIO ANTENNA COAXIAL COAX CABLE ~ TERMINATOR~ HORMETICALLY SEALED | eBay
Old Sep 1, 2012 | 11:40 AM
Smitty12JKU's Avatar
Another option if you need to route through tight spaces and dont want to install you own connector. It has the exterior end with a weather boot and a compact end that has screw on type connector.
K40 CB cable
Old Sep 1, 2012 | 12:23 PM
renzo1200's Avatar
You guys rock, thanks so much for the lighting fast replies!
Old Sep 1, 2012 | 12:35 PM
Sahara Lee's Avatar
Default Fire away!
I really like my Firestik MU-8R18 Coax w/FireRing Antenna Mount with a K-4R antenna stud mount. (note: K-4R has longer bolt for FireRing than K-4) No soildering or crimping. The cable comes with a mini-UHF connector installed and a mini to PL-259 adapter. The mini-UHF makes it easy to route the cable since it is only 7/16" diameter. (For reference: RG-58 coax - 1/4", PL-259 connector - 3/4")
The FireRing keeps the antenna insulated from the mount while providing a strong and corrosion resistant connection.
Old Sep 1, 2012 | 01:11 PM
Vladivar's Avatar
I use the Teraflex mount and am using the Firestik FireRing cable. Works great.
Old Sep 17, 2012 | 03:02 PM
renzo1200's Avatar
that's exactly the same route i took using the Firestik K4A stud mount.
The install went smoothly and I can hear my buddy when he's within 50 ft of me, but we can't communicate at a longer distance.
We're both running similar setups with tailgate mounts and Cobra 75.
Any recommendations on what could be causing the issue? We have yet to tune, so that could be it.
-G
Old Sep 17, 2012 | 03:34 PM
951JEEP's Avatar
is your mount grounded to the chasis? (RF ground and chasis/battery ground are different). Did you tune your antenna with a SWR meter?
Old Sep 17, 2012 | 07:02 PM
renzo1200's Avatar
the mount itself is is not grounded. the radio itself is grounded to the body.
Tuning has not been done, i was hoping i could get some short term use out of it without buying a meter.
Old Sep 17, 2012 | 07:10 PM
arjeeper's Avatar
The radio should have positive and negative connected to the battery and a coax connection. Nothing else. The antenna mount is what you'll ground.
Get the mount grounded, check your SWR with an external meter and go from there.
