Did I blow up my Cobra 75?
Old Sep 2, 2009 | 07:28 AM
Skippman's Avatar
Default Did I blow up my Cobra 75?
I'm getting this weird whine throughout all the channels now. It's not there when the vehicle is very first turned on nor does it start at any particular time. I'll be listening to channel 19 on the way home then this whine starts to build up and hold. Doesn't matter what station I'm on, how my squelch is adjusted, or even if the vehicles running. It's not alternator whine as I'm familar with that from my car audio days. Don't know what else it could be. We tuned the antenna to a SWR of 1.2 on 19 and 1.5 on 4 and 35. I'm at a loss.
Old Sep 2, 2009 | 08:47 AM
Desert Fox's Avatar
Veteran: Navy
Smile
Depending on where you have installed the junction box, the whine could be caused by a nearby fan motor. Just a thought. You may want to turn on the vent fan and run the switch from low to high and see if the whine reappears.
Windshield wiper motors can also cause a whine in some radios. Give it a test.
Old Sep 2, 2009 | 09:28 AM
Skippman's Avatar
will do tonight. Right now it's mounted under the glove box where pretty much every other C-75 i've ever seen is.
Old Sep 2, 2009 | 09:38 AM
Desert Fox's Avatar
Veteran: Navy
Smile
I just thought of an other possibility. Make sure that you have the Sound Tracker option enabled. There should be a ST on the screen when you have it turned on.
Old Sep 2, 2009 | 09:39 AM
whpony96's Avatar
Where did you tap in for the 12V+ and the ground?
Have you ever turned it on and Q'd the mic without a antenna mounted? This will from what I'm told cook a CB pretty quick...
Old Sep 2, 2009 | 12:33 PM
Skippman's Avatar
Radio was never turned on without a load, either a SWR meter or an antenna.
Radiios power comes direct from the positive of the battery and I have it grounded to the same grounding stud I'm using for my passanger side Lightforce light.
Old Sep 2, 2009 | 12:48 PM
whpony96's Avatar
I would tap into either cigar lighter wires. (One is ALWAYS Hot the other turns on and off with the key) I used the ground wire from the cigar port as well..no body grounds.. That's why your stereo uses a wire in the harness for a ground and not a body ground. To avoid noise.
I am using the switched cigar port and I have zero noise... Solder the wires no cheapie crimp do-dads.
If you don't have time to do it right the first time, when will you find the time to do it right?
Old Sep 2, 2009 | 06:23 PM
AK4Dave's Avatar
It's hard to say if you smoked your CB. But you said....either a SWR meter "OR" antenna. Don't know quite what you mean here. If you key'd the mic with your coax only connected to a SWR meter, that's as good as not hooking it to anything. The SWR meter does not take the place of an antenna....it is NOT a dummy load. So if you did this for an extended amount of time, then yes, you may have fried your radio.
I have to ask as well........do you still have the whine if your squelch it turned all the way up?
Old Sep 2, 2009 | 07:04 PM
beaquel's Avatar
Skip, at least you are in better shape than I am. I was never able to get my SWR below 3 anywhere it was tested. I can only dream of numbers that low. I still get my whine whenever the engine is running, but Cooltech did send me a bunch of detailed troubleshooting steps to try.
Old Sep 3, 2009 | 06:09 AM
scotlandjk's Avatar
hey skippman.
ive got a midland 42 handheld, its almsot the same as the cobra and i have the EXACT same problem.
i did at first before i knew anything about cb's and swr's expose my cb to an swr of 9 for some time. i now cant even get any transmit power bars up when holding the transmit button.
i think mine is fried, but does anyone know how to tell for sure???
cheers
Dom
