Full sized CB
I was looking at that before. I'm just not sure I want to tear all of the factory plastic out of the Jeep. lol. I know it gets marked up pretty easily. It just looks like its a pain to tear all that out and install ALL that Tuffy stuff. It would be easier and cheaper to just pull the console out of there and put the Tuffy one in it's place and leave all the rest of plastic in front of Tuffy console.
I was also thinking about the Tuffy overhead console. Either one is a great way to go, but they are a little steep on the price. Are you listening Tuffy? LOL I need a 50% discount. lol.
If anyone has used either Tuffy console could you chime in? Let me know how the install went, and also how you like it?
I have the cobra 29 nw st le. I was looking at the dimensions and I don't know if it will fit. Also it's been so long, (plus I drive tractor trailer) I don't remember if my mic comes out the front of the CB or the side.
I just upgraded the center console to the Tuffy. I have the Auto Trans and the install is pretty straight forward. You must remove the seat bolts from both seats so you can flop them back out of the way, no nead to remove them from the vehicle but it would make things alot roomier! The directions to remove the factory plastic is easy enough and I have the electric windows on a 4 door, still no big deal. the putting in of the new Tuffy takes some finese (sp). I have an 09 with the little cargo net at base of dash, first remove this! or you will scratch it up
The instructions get a little week here and there is a definite order of operations to be done!
As instructed, install wiring for the power point(cigarette lighter) then assembel the inside of the box divider(s) you have 2 choises, one is for a radio as pictured or a blank wall for more storage space, I opted for #2.
Put some tape on your shift lever and plastic base trim to protect it and then with 2 people drop the center in to place. It bolts back down to the factory 4 points and you can add 2 more bolts with drilling 2 holes in floor for more security.
all in all not bad and I really like the raised SOFT arm pad!
Thanks.I just upgraded the center console to the Tuffy. I have the Auto Trans and the install is pretty straight forward. You must remove the seat bolts from both seats so you can flop them back out of the way, no nead to remove them from the vehicle but it would make things alot roomier! The directions to remove the factory plastic is easy enough and I have the electric windows on a 4 door, still no big deal. the putting in of the new Tuffy takes some finese (sp). I have an 09 with the little cargo net at base of dash, first remove this! or you will scratch it up
Thanks for the info, I greatly appreciate it.
I'm also envious of you, because you have my exact Jeep!!!
Thanks. Also how was the install for the overhead Tuffy unit?
I'm assuming you ran your wires from the overhead console to the windshield channel, over towards passenger and down???
I am not sure if the electronic compass would be affected by mounting a CB on the dash but the MyGig antenna would most likely be. That is why we had to make a simple way to relocate the antenna with the Flip-N-Lock covers.
Tuffy
I also 'enhanced' the overhead console with gauges, a speaker, and magnet for the microphone.
js.
Thanks..
