Installing CB
Old Oct 31, 2007 | 03:33 PM
Genesis's Avatar
Default cooltech install
I had no problems installing mine. Once you pry the inner plate out, you just unplug the wire. I think it had a little clip that you had to hold down while sliding it apart.
Old Oct 31, 2007 | 08:06 PM
JEB186's Avatar
Default CB -cooltech
Thanks for the tip, I'll try Saturday again, once I get the pllu apart I'm home free. I HOPE.
I'll update as I get going.
Old Nov 1, 2007 | 01:16 PM
Marc426's Avatar
I did not have any problems with the light and did not remove the bulb. In fact I did not have to un-plug any wiring to complete the complete install. Take a deep breath and enjoy the tinkering! Good luck.
Old Nov 1, 2007 | 02:06 PM
utah-jk's Avatar
I installed the cooltech antenna mount. It was easy. But now my question is where to mount the CB?
Old Nov 1, 2007 | 02:44 PM
jsmoriss's Avatar
Originally Posted by N2rock
Lots of threads on that one (I've been searching the threads the past couple days, so I know there is a ton of info just by searching "cb install".
The forum search ignores everything with 3 or fewer characters. It's a little frustrating. I've had better success using google instead. For example try "cb install site:jk-forum.com".
js.
Old Nov 18, 2007 | 11:05 AM
redmuddog's Avatar
Default template position
Originally Posted by JackMacOKC
They both work well...let us know if you have any trouble installing.
The picture with the instructions is unclear on how to postion the paper template. Can you supply additional instructions? Thanks in advance!
Old Nov 18, 2007 | 03:16 PM
Embalmer's Avatar
im leaning to get that type of cb antena mount, but dont like all the pics of the crooked antenas... im sure I can grind the mount enough tobe able to correct it though
Old Nov 18, 2007 | 04:24 PM
JEB186's Avatar
Default Installed
No totally finished but cool tech mount super way to go. No need to wire my cobra 75. Suggustions on which wires to hot wire it. Lighter wires??? To battery. Any suggestions???
Cool tech is mounted straight up and down - You really can't goof it up. I did not even have to pull out lights since someone gave me the tip... THANKS
Old Nov 19, 2007 | 04:38 AM
JackMac4's Avatar
Originally Posted by toad
I suggest going straight to the battery. I've had my lighters blow fuses with a compressor it didn't like so definately battery is the way to go There is a small hole behind the side panel on the battery side that we just snaked the wires thru to the battery. May need a coat hanger
Thats precisely what I did..red to red, black to black. Easy cheesy.
Old Nov 20, 2007 | 12:25 PM
JEB186's Avatar
Default Thanks
FINALLY.... I have my Cb installed and my hat's off to Cool Tech. Every question I asked they answered, mine installed just like the instructions and the only problem I had was not following them sometimes. ADD... A dumb dude... I had a situation with grounding and if I would follow instructions it would have been easier and quicker... I emailed them and they help me immediately. My antenna is straight just as they said it would be. (Sorry that sounds bad)
I think cool tech is the way to go.
I ran right to the battery for power that's the easy way, thanks for all your encouragement and not to sound like a commerical but for my money Cool Tech mounts the way to go.
