Installing CB
Old Oct 28, 2007 | 04:25 PM
JEB186's Avatar
Default Installing CB
I bought Cooltech CB mount and started to install. OK I'm not dumb but.... I could not get the license light to un plug and was afraid to keep trying for fear I'd damage. The insturctions are clear but doesn't explain if you pull, pry or just swear to get it apart. Any help for this new owner would be appreciated.
Old Oct 28, 2007 | 07:15 PM
OffTopic's Avatar
Did you pop the bulb out first?
Old Oct 29, 2007 | 05:51 AM
HEK's Avatar
HEK
Sorry I don't have an answer for you but can I ask you the vendor you bought this from....and how much...thanks
Old Oct 29, 2007 | 10:42 AM
Embalmer's Avatar
http://www.cooltechllc.com/servlet/Detail?no=1
Old Oct 29, 2007 | 01:01 PM
rfrogman's Avatar
You do not have to remove the bulb to get the inner licenplate frame assembly out. After you remove the mounting screws lightly pry out the bottom of the inner license plate backing. If memory serves me you can remove the light socket by rotating it counter clockwise them pulling it to the rear from behind the inner license plate backing.
Sorry I did not take pictures when I re-routed my amateur radio coax feedline.
Old Oct 29, 2007 | 02:09 PM
JackMac4's Avatar
You can PM cooltech here: https://www.jk-forum.com/forums/priv...do=newpm&u=132
Old Oct 30, 2007 | 05:40 AM
HEK's Avatar
HEK
Originally Posted by Embalmer
thanks...I like this one vs the one from Quadratec that mounts on the rear...
Old Oct 30, 2007 | 06:37 AM
JackMac4's Avatar
They both work well...let us know if you have any trouble installing.
Old Oct 30, 2007 | 08:12 PM
JEB186's Avatar
Default still can't get it
I can get all apart, accept when I go to pull apart the small wire connector inside to get the plastic plate holder away to be able to drill and cut the small opening inside. Sure hope this make sense to someone sounds strange what I am asking and I posted it.
The cooltech will be great if I get the inside plate holder wires off.
Old Oct 31, 2007 | 02:50 PM
JackMac4's Avatar
Originally Posted by N2rock
Please update this when you get it... I ordered the cooltech today and am curious as to what I'm getting in to here.
If you do a search, this has been installed by several people. Should be plenty of pictures out there.
