Interference
Old Jul 21, 2011 | 08:35 AM
  #31
Vernnz's Avatar
Hitch mounting would be convenient but it will raise your ground losses. You need the ground plane under the antenna. That might actually make things worse; weaker transmit, weaker & noisier receive.
Old Jul 21, 2011 | 04:48 PM
  #32
goldtr8's Avatar
FYI I have ferrite beads on each ignition wire to help cut the noise on my 08
#31 beads
Old Jul 21, 2011 | 06:07 PM
  #33
AK4Dave's Avatar
Yes.....when he's moving down the road that could be true. But I think he mentioned being parked or contesting, which should be fine. He could even run a few radials off it when he is stationary. I think it's a great idea. Heck....by the looks of it, he could probably even mount a full size Hustler to that thing....
Old Jul 23, 2011 | 03:42 PM
  #34
rpaulson's Avatar
#31 beads
are those 1/2 or 1/4 cord?
http://www.amazon.com/Ferrite-Core-C...1464492&sr=8-1
http://www.amazon.com/Ferrite-Core-C...1464492&sr=8-3
Old Jul 24, 2011 | 01:31 AM
  #35
AK4Dave's Avatar
Says they have 1/4, 3/8 and 1/2.....
Old Jul 24, 2011 | 09:36 AM
  #36
RedDavid's Avatar
It may cost a bit more but I always buy my beads from dxengineering.com. High quality and the right mix (31). If you get the wrong mix it won't help with HF freqs. I believe the .525 are right for ignition wire.
Old Jul 24, 2011 | 03:34 PM
  #37
rpaulson's Avatar
ahh ok. So these? http://www.dxengineering.com/Parts.a...o=DXE-CSB-525P
Old Jul 24, 2011 | 03:52 PM
  #38
goldtr8's Avatar
Originally Posted by rpaulson
These are the different stuff I purchased, you will need the bigger ones for some of the other noise items you will need to kill. If I remember correct the 275P are what I put on the ingnition wires.
http://www.dxengineering.com/Parts.a...=DXE-CSB-COMBO
http://www.dxengineering.com/Parts.a...o=DXE-CSB-275P
Old Jul 25, 2011 | 07:20 AM
  #39
AK4Dave's Avatar
So did you end up getting rid of all your noise problems Don...???
Old Jul 25, 2011 | 08:02 AM
  #40
rpaulson's Avatar
It's gonna be getting a tarheel 2 come tax time. Gonna mount a fixture to put up my 48 ft of army surplus pole on it with my center fed wire dipole I'm making.
