My Cobra 75 CB and antenna install
Old Mar 15, 2011 | 07:12 PM
  #281
JeepFrog707's Avatar
Just did my install of the Cobra 75. Easily done except for having no soldering iron to connect the cable to the adapter.
Off to Home Depot I go.
I used the antenna mountinbracket that I got with my LOD bumper and carrier and mounted it just above the rubber plug on the tailgate. This allows it to just poke out a tiny bit and not have any cable exposed outside. I also got the 4' blue firestik II with a quick disconnect so I don't break it off going in and out of the garage. I grounded the gate to the body with extra wire even though many write ups say it's not necessary. I also used an AUX cable and hooked it up to the radio instead of buying an external speaker.
I also went directly to the battery with the positive wire so there is no feedback and I can use it while the Jeep is off. This was a very easy install and I even had time to install my JKS Quicker Disconnects.
All in time for Shamrocked this weekend! Woo Hoo!
I'm also picking up a Simpson Strong Tie while I'm at Home Depot and custom making my own mounting bracket instead of paying $20 plus shipping for the Cooltech Versamount. I revived an old write up here....
https://www.jk-forum.com/forums/show...ernative/page2
Here's some pics of my mount and antenna....
Old Mar 16, 2011 | 07:52 PM
  #282
While getting the antenna tuned the CB shop guy said that if my quick disconnect hits that metal screw I'm gonna fry something and I won't be happy. I came home and wrapped the quick disconnect and base of the antenna twice with electrical tape.
Just an FYI for those with quick disconnects and/or have a mount too close to metal.
Old Mar 16, 2011 | 08:50 PM
  #283
Fenrir's Avatar
Good to know.
Couldn't you just flip that mount the other way around, with "L" bracket upside down? I think that would avoid hitting the metal screw.
Old Mar 16, 2011 | 10:49 PM
  #284
Originally Posted by ilflyya
Good to know.
I was thinking about that. Or putting it on the bolt below that. I just don't want to dremel off anymore paint than I already have under the current bolts. I'm gonna be washing it tomorrow and gonna see if I can flip it without a lot of cable showing. I'll post a pic tomorrow after I get it all set.
BTW...he also said it's a common problem with the disconnects. People tap them on the body or carrier while attaching or disconnecting and poof!
Old Mar 17, 2011 | 03:56 AM
  #285
OH9JK's Avatar
JK-Forum Ambassador
Turn your radio equipment OFF while connecting/disconnecting your antenna and there will be no problems.
Old Mar 17, 2011 | 05:19 AM
  #286
JK-jeepit's Avatar
you could always sleeve it with an old bike innertube... or tape it..
Old Mar 17, 2011 | 08:07 AM
  #287
wrapped it up twice with electrical tape.
Old Mar 17, 2011 | 08:05 PM
  #288
And flipped the mount up today. I like it much better and I can reach it easier.
Old Mar 17, 2011 | 08:10 PM
  #289
Fenrir's Avatar
Lol, I think this is why I've never had an issue with mine. It's always off when I disconnect
Old Mar 28, 2011 | 08:31 AM
  #290
dubyas-eep's Avatar
what is everyones comments on the 75, other then sound, will probably use the cable to the aux.
reception? convience? troubles? pratical?
