Question about Teraflex JK cb antenna mount.
I read in one of the threads here that the Teraflex tailgate mount does not provide an adequate ground. So riddle me this: if I establish a good contact between the antenna and mount, and then run a ground wire from the mount to the chassis/frame, will that provide a ground for the antenna?
Are you talking about the old TF bracket that mounts on the stock tire carrier or the new hi-lift and CB mount that works with the new HD hinge? I have the old bracket and I took the powder coat off of one of the mounting holes and I am getting a solid ground without using a strap so you might want to try it before you worry about the ground strap.
The problem people were having was with the powder coat. Just remove the powder coat from your contact points. It's thick ( powder coat ) and you're gtg. I added a grounding strap to ground the gate to the body as well. It's hidden under the hinge covers. Don't waste your time with a ground wire. It needs to be a flat grounding strap. The wider the better.
Sent from my SPH-L900 using Tapatalk 2
I have Firestik everything....Firering, mount, quick disconnect, spring and Firefly antenna. And with my set up, my SWR is 1.5 on channel 1 and goes down to 1.1 around channel 8 and stays flat through the rest of the channels.
I'll show you mine if you show me yours.
I grounded mine right from the mount through the tailgate and grounded it inside the cab. I'm still getting a lot of feedback and my SWR still high. If I honk the norm, I get feedback through the CB. Any ideas?
