Question about Teraflex JK cb antenna mount.
Old Feb 6, 2013 | 02:35 PM
wvwannabe's Avatar
Default Question about Teraflex JK cb antenna mount.
I read in one of the threads here that the Teraflex tailgate mount does not provide an adequate ground. So riddle me this: if I establish a good contact between the antenna and mount, and then run a ground wire from the mount to the chassis/frame, will that provide a ground for the antenna?
Old Feb 6, 2013 | 02:46 PM
kssting's Avatar
Are you talking about the old TF bracket that mounts on the stock tire carrier or the new hi-lift and CB mount that works with the new HD hinge? I have the old bracket and I took the powder coat off of one of the mounting holes and I am getting a solid ground without using a strap so you might want to try it before you worry about the ground strap.
Old Feb 6, 2013 | 03:55 PM
shockwaveaz's Avatar
The problem people were having was with the powder coat. Just remove the powder coat from your contact points. It's thick ( powder coat ) and you're gtg. I added a grounding strap to ground the gate to the body as well. It's hidden under the hinge covers. Don't waste your time with a ground wire. It needs to be a flat grounding strap. The wider the better.
Sent from my SPH-L900 using Tapatalk 2
Old Feb 6, 2013 | 04:40 PM
wvwannabe's Avatar
I will getting a ground strap and doing some grinding. Thanks for the help!
Old Feb 6, 2013 | 06:05 PM
Sabotage70's Avatar
I did the exact same thing. I knew right off the bat the PC had to come off of the braccket. But I looked all around and couldn't find anything on how to run the ground strap. The last thing I wanted was a 18" strap to snag who knows what in the back.
I have Firestik everything....Firering, mount, quick disconnect, spring and Firefly antenna. And with my set up, my SWR is 1.5 on channel 1 and goes down to 1.1 around channel 8 and stays flat through the rest of the channels.
I'll show you mine if you show me yours.
Old Feb 6, 2013 | 09:22 PM
That is exactly how I ran mine. :thumbup:
Old Feb 7, 2013 | 08:42 AM
TeraFlex's Avatar
Sponsoring Manufacturer
TeraFlex now offers a stainless coated CB mount #4997191 $44.99.
Old Feb 7, 2013 | 02:38 PM
jk4thedirt's Avatar
I grounded mine right from the mount through the tailgate and grounded it inside the cab. I'm still getting a lot of feedback and my SWR still high. If I honk the norm, I get feedback through the CB. Any ideas?
Old Feb 7, 2013 | 03:04 PM
Dkjk's Avatar
No need for a ground strap. I just sanded off the coating where the antenna mounts. Works perfectly fine.
Old Feb 7, 2013 | 05:29 PM
Jk alternators are noisy. You need a real solid ground for your power and should run the +12 to the battery. You may need a noise filter if you are getting bad feedback still. Also, make sure your feed wire is quality and the right ohms to get low swr. I have had bad luckwith Radio Shack cables. Do you have excess wire wrapped up? Thats a no no too.
