Question about Teraflex JK cb antenna mount.
Old Feb 7, 2013 | 05:55 PM
jk4thedirt's Avatar
Originally Posted by shockwaveaz
Jk alternators are noisy. You need a real solid ground for your power and should run the +12 to the battery. You may need a noise filter if you are getting bad feedback still. Also, make sure your feed wire is quality and the right ohms to get low swr. I have had bad luckwith Radio Shack cables. Do you have excess wire wrapped up? Thats a no no too.
Sent from my SPH-L900 using Tapatalk 2
Thank you for the help. I did go directly to the battery for power, but used the ground lug on the passenger footwell area. I just used a 6 gauge wire for the Antenna ground. No excess wire, I barely had enough coaxial cable to reach the CB. Should I change the antenna ground wire? I can stop by a truck stop tomorrow for any supplies.
