So where have you been mounting the CB's?
Old Sep 3, 2007 | 06:20 PM
  #21
Octane's Avatar
Originally Posted by jeepingib
I think he's talking about the center stack, as in below the power outlet and switch area.
thank you, that is what I meant. Like right in front of the shifters...
Old Sep 7, 2007 | 11:33 AM
  #22
VTXSPres's Avatar
I screwed mine into the radio speaker bridge on the roll bar. I used the dome light wire for power (with an inline fuse) and the ground in the dome/speaker module for the ground and I mounted the antenna in a factory hole in the body. Works well, but I'm missing my dome light and the CB will shut off about 30 seconds after the truck is turned off. I'd like to find a separate always-hot wire for the CB and dome to share. Is there any type of always hot wire in the JK like there is behind the glove in the TJ?
Thanks!
Old Sep 9, 2007 | 07:23 PM
  #23
Octane's Avatar
CB mount in dash under factory buttons in front of shifters is where I wanted to put it. If I mess up, I found out that OEM plastic piece that seems simple enough to cut is about $35 from Jeep. lol.
Old Sep 9, 2007 | 08:22 PM
  #24
Rugbyduck's Avatar
Name:	101_0114 - Copy.JPG
Name:	101_0115 - Copy.JPG
Old Sep 10, 2007 | 04:18 PM
  #25
gldwings1's Avatar
Another option if you like is the tuffy overhead console and there is a dash hoop with a center plate that runs back to the roll bar made by I believe High Rock. It's available from 4 wheel parts.
Keep the shiny side up,
Chuck
Old May 4, 2008 | 07:26 PM
  #26
Slimjim's Avatar
Default Show off you CB radio here.
I need ideas for places to mount my CB radio, and sence i cant search for "CB" Im starting a thread. I have a full size Cobra 29.
Old May 4, 2008 | 07:41 PM
  #27
Eracer76's Avatar
Here is my custom install location of my Galaxy DX 929...
It is a tight squeeze in there, but it fits perfect...
Old May 4, 2008 | 07:57 PM
  #28
Slimjim's Avatar
How did you do that? What did you use to cut out the hole?
Old May 4, 2008 | 08:39 PM
  #29
Jordo89's Avatar
that looks sweet.... too bad my amp is there.
Old May 4, 2008 | 09:22 PM
  #30
pkess3's Avatar
Get some mounts from AZ rockyroad. You can use their mounts for all kinds of stuff
