So where have you been mounting the CB's?
Old 10-21-2008, 05:45 PM
  #81
Gokracer1's Avatar
Mine is here along w/ where I mounted my External CB....
https://www.jk-forum.com/forums/show...ternal+Speaker
Old 10-22-2008, 04:38 AM
  #82
scottrock's Avatar
Here's mine mounted in front of the shifter
I did have to cut the mounting bracket down 1/2" so the shifter didn't rub on the radio. Also clearanced the rubber boot on the end of the coax so it would sit low enough to not be in front of the ESP and hazard buttons. A 90deg coax adapter would have done the trick ut I'm a cheap bastard.
Old 10-23-2008, 03:38 PM
  #83
rickc309's Avatar
Overhead above the mirror for me.... Out of the way.
Old 10-24-2008, 09:28 PM
  #84
RedDavid's Avatar
So, what's the story with the ground wire that looks to be attached to the antenna wire and grounded to the antenna mount? Is there a splice in the antenna wire or? How do I know if i need a ground wire like that?
BTW my antenna is mounted to the 3rd brake lite. CB is grounded to the body. SWR is between 1.2-1.6 or so on channels 1-40.
Old 10-26-2008, 05:57 AM
  #85
Until2004's Avatar
I mounted my Cobra 75 under the passenger seat and the antenna on the spare tire mount.
Old 11-12-2008, 10:14 PM
  #86
noot's Avatar
Has anyone mounted their CB under (and attached to) the lid of the console?
Old 11-27-2008, 02:00 PM
  #87
Robicon's Avatar
Thumbs down ??
Originally Posted by jobrien
Here's mine;
No offence but yours looks like a clusterfu*k of extra wires
Old 05-16-2011, 05:44 PM
  #88
tford911's Avatar
Originally Posted by 07 RBY
Here's a couple of pics. I still would like a permanent place to connect to power.
do you hit your leg on it? im tall and when i drive my leg is usually resting on the 4wd shifter so i think that would just b in the way
Old 05-25-2011, 06:04 PM
  #89
MasterG's Avatar
:subscribed:
Old 05-30-2011, 04:56 PM
  #90
Noxian's Avatar
I ended up putting mine below the glove box on the passenger side, not many other options on the 2011 from what I could figure out
Quick Reply: So where have you been mounting the CB's?
