Yaesu FTM-400DR Install
Old 08-09-2015, 01:52 PM
LHC30's Avatar
Default Yaesu FTM-400DR Install
Well, I finally earned my Tech HAM license and decided a good mobile unit was in order. Couldn't resist the Yaesu for the bigger display and features that should keep it current for several years.
JK's are not known for their room and trying to fit a CB and HAM in the cabin without hurting your knees is a challenge. I ran across a pre-made under seat mount that made things easy. I decided the only place left for the antenna was a hood mount and that is where my Diamond 2m/70cm antenna is (thanks MrKenmore for your ideas). I used the rubber plug by the brake booster to run the power (ran to the sPod) and antenna cable. As you can see, I had to loop the coax a bit. The jury is still out if I am going to cut it or not. Managed to re-use the stock connector mount for the seat wiring also! I ran the control cable up along the left side of the HVAC and Radio to the dash tray. I ran the mic cable around the center console. Made a prototype mount for the head unit that uses the dash mount screw in the tray. So far, So good. Whatchathink?
ID:	620924   Click image for larger version
ID:	620925   Click image for larger version
ID:	620926   Click image for larger version
Old 08-09-2015, 02:05 PM
edshults's Avatar
Awesome !
Old 08-09-2015, 02:11 PM
LHC30's Avatar
I thought it fortunate I was able to save the factory connector mount for the hard plate. The connector won't rattle! All the holes except the radio mount to plate are threaded. The cable wrap anchors are 8X32 threaded and work well.
Old 08-09-2015, 03:20 PM
Desert Fox's Avatar
Cool Excellent
Solid install ! Where did you find the under seat install plate? I have been looking for something like that for years.
Well Done !
73 - W6PBR
Old 08-09-2015, 05:06 PM
LHC30's Avatar
I found the undersea plate on Ebay. Sold by Jeepedjeep. He is on Wrangler forums but cannot sell from there. 30 sumptin dollars and shipping....Well worth the time....
Old 08-10-2015, 06:57 AM
LHC30's Avatar
Several folks wanted info on the underseat tray so here is the ebay link:
Jeep Wrangler JK JKU Under Seat Bracket with Mounting Options | eBay
Old 08-20-2015, 06:07 AM
Skippman's Avatar
Awesome install man! Wonder if you could install two radios side by side on that plate.
Old 08-20-2015, 07:34 AM
LHC30's Avatar
As small as these units are, I could get FOUR on that plate...
Old 04-09-2020, 12:35 PM
TWGeary's Avatar
Where did you buy the pan under the seat?
Quick Reply: Yaesu FTM-400DR Install
