Adding Lights to RSE Bumper. Need Some Advice
Old May 30, 2021 | 08:03 PM
Lark75's Avatar
Default Adding Lights to RSE Bumper. Need Some Advice
I bought a new to me 2012 JK with
Rock-Slide Engineering R-SE Rigid Full Front Bumper with Bullbar (Black) - FB-F-100-JK installed, including a winch.
Any advise on what lights to install in the 6 inch holes? Any chance the lights can be wired into the fog light switch on the column?
Thanks in advance for any tips
Lark
Old May 31, 2021 | 04:14 AM
resharp001's Avatar
Loved
Community Favorite
Welcome to JKF Lark. Your original post was in an old thread from 2009, and while there is nothing wrong with that, it was much less likely that people would see it and take the time to read/respond, so I moved your post to it's own new thread. I am not familiar with this bumper, but I did notice on Quadratec's listing that it noted this -
Here is a link to those lights on Amazon (look cheaper than other retailers) -
https://www.amazon.com/PIAA-5293-Cry.../dp/B000182E28
There may be some other options out there for 6" lights. For those PIAA lights specifically, it looks like they have a big wiring loom to go to the battery with a switch to trigger them. I'd bet you could splice in the factory fog wiring into that so you could trigger them off the switch on the stalk in the jeep.
Old May 31, 2021 | 03:38 PM
Lark75's Avatar
JK Jedi. Thanks for the info. Another dumb question. I could not figure out how to start a new thread. Is there’s how to guide I have yet to find. Thanks again for the help.
Old May 31, 2021 | 04:49 PM
resharp001's Avatar
Loved
Community Favorite
I'm usually cruising through the "new posts", but you can maneuver to the appropriate sub-forum through the banner like this -
Once in a sub-forum, there is a "new thread" button at the top that you can create a thread to -
We have a decent group of members that are around on a regular basis as support. There is nothing wrong with posting in an old thread, but sometimes we'll move something if we think it's beneficial to the OP getting some help.
Old Jun 15, 2021 | 07:08 PM
Lark75's Avatar
Ok. New question. My JK has the fog light switch on the stalk. Does this mean there were operating fog lights on the original bumper?
Old Jun 15, 2021 | 07:15 PM
resharp001's Avatar
Loved
Community Favorite
I think even the cheapest non-optioned JK came with fogs in the bumper. The downside of where I think your train of thought is going is that most aftermarket lights, specifically LEDs, aren't going to play nice with the CANbus and will flash if you try to use that wiring so you can control them from the stalk.
Old Jun 18, 2021 | 07:20 PM
Lark75's Avatar
Reshsrp001. Very good point about the computer. I will try to go the low tech route with an incandescent for light. Will post what happens.
Old Jun 19, 2021 | 02:14 PM
CJ's JK's Avatar
Veteran: Navy
If you use a relay and only use the "power wire" from the stock driving lights as a signal wire, it would be fine. I added LED reverse lights to my hitch receiver using the reverse light "power" in the right taillight as the signal and tapping into the aux plug in back for the 12v power.
Old Jun 19, 2021 | 03:55 PM
resharp001's Avatar
Loved
Community Favorite
Good point.
