Auxiliary Fuse Box
#21
GARY! you got the painless? youve been making me suffer all this time Ok, well it looks like im going to bother you for your garage one more time and try to hook it up along with my CB i just ordered.
#24
Painless setup
Here is a pic of my setup. Got the painless block from 4wd.com and mounted behind the panel under the glove box. I added a couple of terminal blocks to clean up the install since I was only using two fuses at the time. I did have to fab a mounting bracket and spent a lot of time terminating and heat shrinking but in total took probably 3-4 hours.
#29
Thanks, this is great for in cab power for switches an accessories but I plan on installing the bussmann relay panel next in the engine compartment to power lights and possibly OBA
#30
Low cost Aux Fuse Box
Got the fuse panel for $14 and the box from radio shack for $4.99 and had to buy some connectors and fuses so I have about $35 into it. Will allow me to add up to 8 fused therminals - would rather have had ring therminals but I don't think I will really have a problem with the push ons. You can still open the stock fuse box of course. I made a mount so the Aux. fuse box mounts to the dual battery tie down. It is very secure. Still took a few hours it install..... Now I need to clean up the solar panel install.
