Lights Flicker
Old 10-15-2009, 10:54 AM
wazooz2424's Avatar
Originally Posted by JulianK
I thought it was. I used a round wire terminal and screwed it onto an existing ground wire set on the side of the inside fender. Should I ground it seperately? Would that cause the symptoms I described?....especially after running fine for weeks. ???
anything is worth a shot. back when i did car audio type work, i never ever used a pre existing ground. i would give that a shot, and then maybe follow the directions you quoted above.
Old 10-17-2009, 07:48 AM
JulianK's Avatar
Ok, Here are the wiring instructions for the lights. The red wire from the switch is the one I tapped into the headlight high beams...seems to me it just goes into the switch.
Quick Reply: Lights Flicker
