Problem with radio
Old Nov 22, 2006 | 03:28 AM
thrash's Avatar
Default Mine also does this when closing two windows ---
It has done since day one. If I put up two windows at the same time, when the windows hit the top of the frame and bed in, the radio reboots. I am guessing that the extra power drawn by the window motors at that moment when the windows stop moving causes just enough of a power drop that the radio no longer has enough juice to continue functioning.
It is a tad annoying, and I would really like to hear what a dealer has to say about the issue.
Old Nov 22, 2006 | 05:51 AM
Ge99ne's Avatar
I'm in the same boat as you. happend twice the other day when putting both windows down.
Old Nov 22, 2006 | 06:14 AM
LynDi's Avatar
Exclamation Update on problem with radio
Apparently the wire harness for the radio(?) was not fully plugged in. This isn't the first time on this jeep that something wasn't fully plugged in, just two days after buying the jeep our engine light came on and we found out that an 'OS sensor' wasn't snapped together (?). Don't get me wrong overall the jeep is great, it is just these "little" problems that arise that makes me think the factory should be double checking their quality control.
Jeep Wave to all.
Old Nov 22, 2006 | 06:27 AM
wayoflife's Avatar
JK-Forum Founder
Hey LynDi, thanks for the update. I'm glad to hear your problem was something so simple and easy to fix but man, that really is stupid Hopefully, that'll be the last of your boogers to deal with.
Old Nov 22, 2006 | 10:59 AM
Fuzzy™'s Avatar
Sponsoring Vendor
Quadratec Rep
Unhappy
My air bag sensor wasn't plugged all the way in... the dealer had to take the passeger seat and console out...
With the Charging System & ETC issues I've had, the dealer had to flash the computer (TSB NOV 18)
Old Nov 27, 2006 | 12:26 PM
Archer's Avatar
Hey LynDi, any problems since the visit to the dealer? (Just in case they couldn't reproduce the problem and gave you a story)
Old Nov 28, 2006 | 04:38 AM
LynDi's Avatar
Archer, funny you would ask that... Just a week ago I took the JK into the dealer for the radio problem. My hubby and I thought (key word thought) the problem with it was fixed, but just this past weekend the same things started happening again as before; radio shutting off for a sec or two when in reverse or shifting into first. Needless to say we are in the same boat as before:sad: . SO I will be taking it back Friday morning.
By the way nice to see another person from Wyoming. I might be living in CO but the heart still belongs to Wyoming.
Old Nov 28, 2006 | 04:06 PM
marquis's Avatar
Default TSB for radio cutout
LynDi -
If you go back to the dealer for the radio cutout issue, make sure he perfroms the TSB that flashes the engine controller.
Old Nov 30, 2006 | 04:54 AM
dougr5150's Avatar
It snowed here and I was playing, if I jam on the brakes and the ABS kicks in for more then a couple of seconds the radio will shut off. Let off the brakes and it comes right back on.
Old Nov 30, 2006 | 08:37 AM
SpudRacer's Avatar
I wonder if we need to change the power supply to the radio to avoid voltage drops from other electrical equipment. It sounds like they are running too many electrical components through one circuit. I wonder if anyone who's fortunate enough to already own their Jeep, and is having this problem can troubleshoot for the rest of us. I recommend getting a multimeter, and checking the voltage at the power outlet in the center of the dash, then do whatever it is you do to cause the problem while a passenger watches the volts. See if we are getting a significant voltage drop in the system. It may uncover the cause for the radio dropping out.
Once the Mygig comes out, it's going to become a much bigger annoyance when your nav system shuts down, then has to wait to reboot.
Since I'm going for a Pioneer AVIC-Z1, I think I'll avoid this whole issue by running a different power wire for the radio.
Tom
Bryson City, NC
