uConnect mic / Aftermarket mic position
#21
Not to Jack the thread but I want to install this too but my Jeep doesn't have the MyGig and is marked REQ on the bottom right face. It'a a 2008 Sahara.
Will I be able to purchase/install a Mic and have it programmed? Also do the stealerships charge to program this. Oh... I'm currently using a simple AUX cable for my I-Pod. Will the re-program of the head unit change anything?
Thanks guys!
Thanks guys!
#22
Don't know on the previous software, but just press the uconnect button and say memo.
#23
Does anyone have photos (real photos, not a diagram) of how to take apart the dash? I've searched and didn't find anything. I'm a "show me, don't tell me" kind of learner.
#24
I ordered the mic but do not have it yet but from what I thought you do not have to take the dash apart only the black top part over the radio then reach in behind it and plug the mic in.
#25
I don't think you can reach behind with just top black thingy off. I can't see how your hand can get behind and plug the harness. Taking apart the front is not that hard anyway... remove Top black plate. Remove bottom plate. remove 2 screws each behind top and bottom plate. pry open/pull with little force the face cover and remove remaining 4 screws to get the radio out. I may have pics somewhere on my lappy..If I find I'll post it. Actually coastaletech has a video of mygig lockpick installation on their site that shows exactly how to open the radio.
#26
#27
The Mic works great and was no problem setting up.
#28
I have a BlackBerry Bold, MyGig Nav, and a factory mic and mine sucks. Everyone complains about it when I use it. I have to crank the volume on the radio waaay up so they can hear me. I need to play with the mic placement I guess. I don't ever use it anymore because it sucks so badly. This is on a stock '08 Rubicon hardtop with the windows all rolled up and the top on. I've never bothered with the top off or the windows down.
#29
#30
monday i finally installed my lockpick. i've read it several times b4 on the forum, but i will give u my advice and say it again... BE CAREFUL WITH THE PLASTIC, it scratches very easily! Good Luck
