JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
Wheel spacers
Old Dec 2, 2017 | 05:58 AM
silverbullit07's Avatar
Default Wheel spacers
Contemplating putting wheel spacers on my 07 JK. What are the pros and cons? input greatly appriciated
Old Dec 2, 2017 | 08:31 AM
caryt's Avatar
I've ran them without issues just get good ones from either Motorsport tech in Sparks or Spidertrax.
Old Dec 2, 2017 | 07:19 PM
nthinuf's Avatar
There are some links in post #6 that might be helpful.
https://www.jk-forum.com/forums/modi...s-safe-317080/
Old Dec 4, 2017 | 05:01 AM
resharp001's Avatar
Loved
Community Favorite
I'd much rather have properly backspaced wheels, but alas I'm currently running spacers myself. As already suggested, buy quality.....not some cheap ebay spacer. Install properly and maintain em. I typically just double check the lugs when I have wheels off for whatever reason....which for me is pretty occasionally. No issues yet with used set of Spidertrax I picked up a while back.
Old Mar 31, 2018 | 04:41 AM
eng23ine's Avatar
Be sure whatever spacers you buy are hubcentric, make sure to remove all of the brake rotor assembly clips, torque spacer lugs to 100ft-lbs.
There's zero difference between the $90 ebay spacers and the $200 spidertrax spacers.
Old Sep 23, 2018 | 06:38 PM
Big-Foot's Avatar
Veteran: Navy
I think there’s a pretty big difference in quality when you compare machined diecast spacers with machined billet spacers...
SpyderTrax spacers now have a recess machined into the backsides of the spacers that allow you to keep the rotor retention clips.
Before installing any spacers, it’s a good idea to wire brush any rust from the hub and face of the rotor that the spacer will mate to. From there, a thin coating of antiseize around the hub - wiping off excess residue - will keep your spacers from corroding and locking onto your hubs in the same manner that most of our hub-centric alloy wheels do...
Randy
Old Oct 1, 2018 | 06:47 PM
lowendrider's Avatar
Been running spidertrax for about 2 years now with no issues. No downside as far as I can tell, unless you run into a tire store that won't fool with them when it comes time to have some work done .
