Old Jan 8, 2013 | 07:31 PM
  #2031
Jeered's Avatar
Originally Posted by Cool Danish
I looked into that before I decided to make my own dual battery tray. I actually was playing around with the idea of mounting the Auxillary battery underneath the Jeep, right in front of the EVAP canister.. But that required heavy skidplates etc..
The problem with a remote mounted battery in the rear of the Jeep is that you would have to add a bulky high Amp fuse to both ends of the positive cable running between the Main and Auxillary battery. Additionally heavy gauge battery cable is fairly expensive for longer runs.
So it makes more sense to go the dual battery tray route.
M.O.R.E makes one for the 2012.. and previous poster said Nemesis Industries makes one also (I have only seen one picture of the Nemesis Industries one and read somewhere that they were not ready yet?)
BTW I also have the 50qt. ARB fridge and absolutely love it.. Probably the most useful Overland toy I have purchased... I agree with Mark D. that the ARB safety auto-turn off feature, turns off too soon, especially when you run it off the outlet in the rear of the 2011+ models (Sahara/Rubicon).. Chrysler skimped on the wire gauge for that outlet.. Sure you can pull +15amps off the outlet, but your Voltage drops significantly over the long run and thin gauge wire. I wish the auto-shutoff feature was fully adjustable Personally I plan to run a dedicated heaver gauge wire from my Aux battery directly to the ARB Fridge.
Thanks for the information. There is a lot to think of before you make decision on going to a dual battery setup.
Does anyone run the spod or something similar with the wiring issues for JKs?
Old Jan 9, 2013 | 05:41 AM
  #2032
GJeep's Avatar
Originally Posted by Dlampe
..... I don't think I have room under the hood on a 2012 for a dual setup.
Tight, but there's enough room.
Dual Optima are even easier to put there, because they're small.
Not quite 'user friendly', but batteries can be installed one above the other, and gel batteries can be installed on their side.
Old Jan 9, 2013 | 06:08 AM
  #2033
zipty05's Avatar
Love following this thread. Awesome rigs and some good advice. Can't wait to get my JKUR ready for expedition but in the mean time here is a picture of my old TJ. Funded by a college kid budget so not much to it and a picture of my current exp til the JK is ready...lol.
Old Jan 9, 2013 | 07:58 AM
  #2034
salmonaediot's Avatar
Originally Posted by Jeered
Does anyone put t battery in the rear of Jeep?
Not a battery per se, but I got one of these as backup. It has served well so far. I am very tight under the hood with supercharger, relays, etc. so this was a good alternative for me.
I also invested in (not an inaccurate term for what they charge for it) the ARB wiring harness for the fridge. It eliminated the goofy cut off problems I had using lighter gauge wiring. I installed it direct to battery and put the outlet here:
ID:	407449Click image for larger version
Steve
Old Jan 9, 2013 | 09:54 AM
  #2035
GJeep's Avatar
..... As alluded elsewhere, any fridge will do a much better job if it is filled up with goods to keep cold, versus trying to keep an almost empty compartment cold.
As air cools faster and warms up faster than solids or liquids, an empty fridge will kick in more often and for shorter durations, than a loaded fridge.
It is better to have longer intervals between the fridge cooling cycles.
On the other hand, a fully loaded fridge will work more, on each cycle, in order to cool more mass.
Old Jan 9, 2013 | 09:57 AM
  #2036
Bubblegoose1's Avatar
I keep mine on, to 32 degrees, with water and Gatorade always.
Old Jan 9, 2013 | 10:18 AM
  #2037
GJeep's Avatar
Originally Posted by KhakiStinger
Nemesis Industries has a dual battery tray for the 2012's
Another one is by M.O.R.E. --
Simpler, lighter, the batteries sit side by side and not one on top of the other,
and at half the price. (not made of Aluminum like the Nemesis)
https://www.jk-forum.com/forums/spon...er-jks-250429/
Old Jan 9, 2013 | 10:35 AM
  #2038
GJeep's Avatar
That's a long thick cable.
Also, AFAIK, smart battery isolators should be connected to the batteries with as similar as possible cable lengths.
Old Jan 9, 2013 | 12:05 PM
  #2039
GJeep's Avatar
Originally Posted by GJeep
'Heavily Lumened' LED lights can be round... check the ARB 'Intensity'.
Very well made and very round, but for a price...
ARB 4X4 ACTION - OCTOBER 2012
Just bumped into yet another round LED light -- by Kar Tek Off Road.
American company, made in USA, for offroading & offroad racing.
Looks like a good heavy duty light.
Kartek Off Road - Scorpion-LED Headlights
Old Jan 9, 2013 | 12:18 PM
  #2040
Cool Danish's Avatar
Default Started my Overland/Expedition Jeep mods.
Here is the begining of my Overland/Expedition build (2012 JKUR, Auto, 4.10 gears):
ID:	407552Click image for larger version
ID:	407553Click image for larger version
ID:	407554Click image for larger version
ID:	407555Click image for larger version
Completed mods:
  • Expedition One Front/Rear bumpers + RubiSkid plate + Rockrails.
  • EVO Skid plates.
  • Warn 9000lbs Winch & Dual beam lights (mounted to front bumper).
  • ARB 50qt. fridge/Freezer & ARB On-Board Air System (CKMTA12) mounted under passenger seat.
  • H3R Performance HalGuard 2.5lb. Premium Fire Extinguisher mounted on rear roll bar.
  • Tuffy JK Conceal Carry Security Drawer + MAG light mounted to side of driver seat.
I am currently working on a custom dual battery tray with Sears Diehard Platinum batteries and Blue Sea Systems ML-Series Heavy Duty Automatic Charging Relay.
Future mods:
  • AEV DualSport 2.5-Inch XT Suspension System.
  • Custom Rotopax gas can carrier that will sandwich between spare tire carrier swing out arm and spare tire (2x 4 gallons = 8 gallons extra fuel). Example see picture in next post.
  • Front Runner 13.2 gallon water tank behind back seat + custom drawer system.
  • Custom water heater tank underneath Jeep, using engine coolant for heat source.
  • Modified Rhino-Rack Pioneer Platform Rack 107" x 57", shortened to ~84". Roof rack mounted with custom brackets thru hardtop onto roll bars.
  • Autohome Maggiolina Air Top Tent - Black Storm medium.
  • Eezi-Awn Bat 270 Degree Awning.
  • Bussman fuse boxes for Main and Auxilary loads (mounted on bracket in drivers side engine compartment close to brake booster).
