Old Jul 3, 2014 | 07:03 AM
  #4151
RAINSTATEBEAR's Avatar
Originally Posted by Gkarshens
I use the Rancho adjustable shocks. When loaded or towing I stiffen the rear shocks and that helps with some of the sag.
Same here
Old Jul 3, 2014 | 08:57 AM
  #4152
Black2013JK's Avatar
I've got the XL9000s but can't see how they help with sag when being loaded. I'm not real smart but don't shocks only help control body movement over dips and bumps? They don't support the weight of the vehicle, that is the job of the springs.
Old Jul 3, 2014 | 09:57 AM
  #4153
Mark Doiron's Avatar
Yep. But a firmer setting may stop you from bottoming out when hitting dips and such.
Old Jul 3, 2014 | 09:58 AM
  #4154
Kansasjk's Avatar
Springs will hold up the jeep. Shocks help too. Nitro gen adjustable shocks will definitely help but worsen the ride correct?
Old Jul 3, 2014 | 10:01 AM
  #4155
Its probably been covered at some point but what are you guys doing to compensate for heavy loads while out and about? I am running a 2.5" TF spring lift which put me pretty level front/rear but when I load up gear I seem to be squatting in the back. I don't mind having a rake when unloaded but didn't know exactly what options are out there. I was initially thinking that a front bumper/winch combo would drop the front enough to level the rig out when loaded but now feel like a rear bumper/tire carrier will drop the rear as well.
What options are there to fix the rake while expo loaded? What do you guys wiuse?
- coil spacer in the rear, how big of a spacer?
- go with a +3" spring for the rear in place of the current 2.5"
- rear adjustable coil spacers (JKS ACOS)
- deal with it
I (and a friend of mine) run OME HD springs in the rear with that lift. Makes a world of difference. If you go light, however, you'll want the TF springs back there. Takes me about 20 minutes by myself to swap those springs.
  #4156
Kansasjk's Avatar
This is a bit off topic. But in your opinions is it worth having a soft top with a rack on the jeep?
Old Jul 3, 2014 | 10:03 AM
  #4157
Depends on your needs. The MBRP rack is gone unless the hardtop is installed. That works for me.
Old Jul 3, 2014 | 10:05 AM
  #4158
Kansasjk's Avatar
Thanks mark
Old Jul 3, 2014 | 10:06 AM
  #4159
Not really an off-road trip, but found a bit of the Old Natchez Trace to follow ...
Old Jul 3, 2014 | 07:51 PM
  #4160
Pepperbrooks23's Avatar
Originally Posted by UKCRD
It is, yes. I made it a while ago out of a fence post and a Landrover 110 replacement bench seat. CUSTOM MADE MOBILE HAM SHACK BENCH SEAT IN 2 DOOR WRANGLER JK 4WDX JEEP WRANGLER JK 2 DOOR MOBILE HAM SHACK
Nice!
