Old Apr 9, 2015 | 03:05 PM
  #4801
crusaderJK's Avatar
Originally Posted by GJeep
Ah... It may be fridge OR freezer, because they don't specify separate volumes for each.
Yes, they do...
Old Apr 9, 2015 | 03:25 PM
  #4802
crusaderJK's Avatar
Originally Posted by kevjeep
I think of my days of boat ownership and using a house battery to charge and run multiple accessories (including a fridge) for a day or two at a time without charging or shore power. I'm trying to think through the ramifications/issues of doing something similar in the trailer configuration.
Thanks in advance for all your input and opinions.
Some carry solar cells, which are better for those who stay awhile in one place.
Solar guy here.
Don't have a trailer, but I do power my 35l fridge with a 75Ah battery that gets it's charge from a 100W solar panel.
I can run that fridge and charge phones and GPS for 4-5 days without sun. When it's sunny the battery is always full.
ID:	605599Click image for larger version
ID:	605600Click image for larger version
Old Apr 9, 2015 | 05:15 PM
  #4803
Saharaunlmtd's Avatar
I'm in NE Ohio and SW PA area (and extreme Norther WVA if you want to include that) and would love to find a resource that provided information on backroads and 4wd trails in this area. Most everything I'm aware of is either a small park/playground pay-by-the-day type place that is really set up for rock crawling or the not-necessarily-recommend-or-legal areas like Wellsville. Given we have mountains in PA (or large hills for you guys out west) I would expect that there are some areas here to take an overland/expedition type trip,
It would be awesome to find a resource like that for this area. My little ones are just reaching the camping age and I've just moved from a becoming-less-than-reliable jk w/ 128,000 miles to a 2015 so I'm in the prime position to get out and explore.
Old Apr 9, 2015 | 05:20 PM
  #4804
GJeep's Avatar
Originally Posted by crusaderJK
Yes, they do...
Attachment 605597
Oh, thanks !
That's good, because I consider the Engel, and the ARB as second in priority.
(just didn't delve into the specs/models yet.)
Everyone I know are using either the ARB or Engel, for years, without any problem. I was the only one with a cheaper fridge, which eventually quit working for good...
The way I'd use it is to fill most of the freezer with ice packs. In case the batteries run low, because of much winch use or whatever, I can pull out the divider plate, shut it off, and let the ice keep it cold until the batteries are fully charged.
Old Apr 10, 2015 | 09:05 AM
  #4805
kevjeep's Avatar
The ARB fridge is among the best, but there's also a real good alternative -- the Engel.
Instead of a regular rotating motor, it has a very simple 'Swing Motor' (An electromagnet resting on coil springs and oscillating inside an electric coil).
You may like the fact that it draws less power than regular fridges.
It is considered to be super reliable.
Link - Engel Website
Thanks I wasn't aware of those. Will need to read up on them both. Their upright DC fridges seem to be similar to what I mentioned from boating. But the line of chest fridges seem to be very similar to ARB from an offering standpoint. Clearly they function differently and I will research that.
Old Apr 10, 2015 | 10:16 AM
  #4806
QPJEEP420's Avatar
Got my new rig started. Now to get on a trail!
Old Apr 10, 2015 | 11:13 AM
  #4807
crusaderJK's Avatar
Attachment 605686
I see you have the Bestop tailgate rack. Did you already have it on your previous JK and can tell how sturdy it is?
Old Apr 10, 2015 | 11:51 AM
  #4808
GJeep's Avatar
You're welcome.
Both the Engel and ARB are very popular in Australia, and not because they're made there, but because they had proven to be very reliable in the harsh outback. Offroading is a way of life there, and they seem to know know what they're doing.
The Engel fridge motor/compressor is supposed to be less sensitive to offroad shaking, but I haven't seen an ARB fail, so this may be theoretical.
As I consider the Engel too, please share what you find
Old Apr 11, 2015 | 03:29 AM
  #4809
QPJEEP420's Avatar
Yes, it was on my other JK. I think it is rated for about 75lbs. I use it for camp chairs and other camping gear that is either dirty or stuff that can get wet.
  #4810
UKCRD's Avatar
You're welcome.
I've been using a Waeco CAB 40 3 way for a couple of weeks now that I bought used for about $120. It's been superb on two trips now and Waecos get good write-ups over here. Worth looking at if you're on a budget. This is mine:
http://4wdx.com/waeco-cab-40-3-way-fridge-freezer/
