Old May 25, 2015 | 07:55 AM
  #4981
horrocks007's Avatar
Need a little reassurance here, or maybe other suggestions.
Thinking heavily about the OME 2 inch lift kit, and am looking for feedback on that kit. I don't like the springs not being progressive, and the shocks not being monotube. But you can't ignore all the people who love their ride.
Also thinking about the rock krawler expedition lift, but more than I'd like to spend. Is this one that much better?
My stock+teraflex leveling kit has settle down to stock height in the rear and near stock in the front from the weight of my Gobi rack, bumpers, sliders, etc. and I have plans to add a winch soon.
I currently run 32.6 inch tires and am still at least 20000mi from replacing them. When I do, 34's would be the highest I could see myself going. I plan for a lot of distance driving being loaded on the rack, and possibly towing a teardrop trailer. So keeping my tire size smaller and more practical will be better for me overall for breaking and getting out of my own way with 4.88's on a 2010.
Old May 25, 2015 | 08:36 AM
  #4982
Mark Doiron's Avatar
I run the OME 300 lb springs on my '07's rear (2.5" TF lift otherwise). A friend with a '12 Rubi had the same configuration. We both had a problem with sag to the bumpstops. Bear in mind, we are heavy--6800 lbs or so. We took two different solutions. He got OME 600 lb springs. I got Timbrens. We both were on the Utah Obscura trip, and we're both pleased with our solutions. I offer this not as advice for what you should do, but as consideration if you think you'll be running very heavy.
Old May 25, 2015 | 10:07 AM
  #4983
kmrtnsn's Avatar
I was in the same boat last year, rolling on a 2.5" Teraflex kit that was sagging under the weight of winch bumper, winch, rear steel bumper, roof rack, etc. I went with OME 300 front/600 rear springs. I also installed Rancho geometry correction brackets, which I would say have done more to returning the ride to "stock" feel than the springs ever could, which I do not find to be harsh. There is a lot to be said about running the correct caster on the front. I am currently still running on a set of Rubi gas shocks and will probably replace them next year with Rancho 9000s. We are running 33" tires, LT285/70R17 on 3.73 gearing, which I an happy with. If I go larger than a 295, I'll re-gear to 4.56. Like Mark said, this isn't advice but rather another example of something working in your particular situation.
Old May 25, 2015 | 01:10 PM
  #4984
Saharaunlmtd's Avatar
Originally Posted by akpostal
Is that a handicap spot?
yes, it is. The employees had me park there for loading purposes only.
  #4985
Originally Posted by Sapper71
what kind of roof rack is that.
It's the Gobi Ranger Rack.
Old May 25, 2015 | 03:23 PM
  #4986
Thanks both for the advice on the lift. I will look into OME springs seperatly.
Old May 26, 2015 | 12:26 PM
  #4987
Got my broken window changed today. Supposed to be only a 20% chance of rain, but this is Oklahoma. Finished up five minutes before the showers started.
ID:	612364   Click image for larger version
Old May 26, 2015 | 02:32 PM
  #4988
Kojack's Avatar
Mark,
How much do the timbrens mess with flex? I know you guys flex a lot in sections of the trails you run...I have them in the front ofmy suburban for the plow and they work great there.
Old May 26, 2015 | 03:43 PM
  #4989
Originally Posted by Kojack
Mark,
Didn't really notice on the rear axle, which was already on the bumpstops. I'd advise against them on the front for that very reason, though.
Old May 27, 2015 | 01:29 AM
  #4990
Kojack's Avatar
Yeah, I would not need them on the front anyways. I needed them with the plow and I would just flatten the suspension on the burb without them. Do they install inside the spring or outside?
I just ordered airbags, I will give them a shot. My dealer treats me really good so if I blow one, I will get a free replacement. I don't run super heavy, but at times will have a load with the pop up on, and camping/traveling gear inside. So, the bags should really help there.
