Front BUMPER comparison
Old Dec 19, 2008 | 03:19 AM
  #271
Skippman's Avatar
Originally Posted by JK-Rubi
Here's a pic I took after spraying the bumper, but prior to applying a coat to the wing supports, and some extra light brackets.
Ok, now THATS a good finish. Just the right amount of "crinkle". In real life does it look more like it's powdercoated or more like it's been Rhino-Lined? What's the texture like? Rubbery or smooth?
Old Dec 19, 2008 | 04:03 AM
  #272
davidmech21's Avatar
Originally Posted by Dylanjam77
Come on... it's okay to admit that you ordered the glitter Line-X finish!
Okay, okay, you got me. I just couldn't resist the glitter finish!
Old Dec 19, 2008 | 04:45 AM
  #273
JK-Rubi's Avatar
It looks more like the black plastic fenders that come stock on non-Sahara JKs. The coating has a "thin" look verses the "thicker" look I've seen on some Line-X'd and RL'd parts (probably has a lot to do with how coating is applied - but I don't know that for a fact). The texture is controlled by spraying the liner closer (smooth) or further away (rougher) from the item being coated. End result is a very hard, definitely not rubbery, finish.
By the way, I would describe the finish/texture on my bumper as medium rough - it's not absolutely smooth, but it doesn't have a jagged appearance either (perhaps high grain sandpaper is a good analogy).
Old Dec 19, 2008 | 04:52 AM
  #274
Skippman's Avatar
JK, thanks for the reply and the new picture. I'm definatly gonna have to do a similar mod to my MOPAR bumpers when I get them. I'm also probably going to do it to the Rubicon's rock rails. I think it'd give me a nice even look around the vehicle and match the plastic fenders better. Plus it will help with running over brush and stuff.
If you don't mind me asking, how much was it to get it Line-X'd and did you have to mask anything off?
Old Dec 19, 2008 | 05:03 AM
  #275
JK-Rubi's Avatar
Default Dupli-color Bedliner
I also used the Dupli-color Bedliner on my Shrockworks Rock Rails. You can see a bit of the process in this thread ---> https://www.jk-forum.com/forums/modified-jk-tech-2/do-these-2dr-shrockworks-rock-rails-look-right-61719/
The Dupli-color Bedliner is about $9 a can (I used two on my bumper), and can be found at most auto parts stores.
Edit: Practice on your rails first, or the inside of your bumper. It's fairly easy to use, but I definitely got better the more I sprayed.
Old Dec 21, 2008 | 07:15 PM
  #276
Here are a couple of pictures of mine installed. I think it turned out pretty good...
Old Dec 21, 2008 | 07:45 PM
  #277
JK-Rubi's Avatar
Looking good David.
Originally Posted by davidmech21
Old Dec 22, 2008 | 05:48 AM
  #278
Looking good David.
Thanks! I'm going to remove the winch cover and spray it this weekend, and install the license plate. I'm already getting plenty of compliments though.
Old Dec 22, 2008 | 06:52 AM
  #279
Ben Hedrick's Avatar
I also used the Dupli-color Bedliner on my Shrockworks Rock Rails. You can see a bit of the process in this thread ---> https://www.jk-forum.com/forums/showthread.php?t=61719
That REALLY looks GOOD! Nice job and good find on the Dupli-Color.
Old Dec 22, 2008 | 06:54 AM
  #280
Skippman's Avatar
Is that the same Dupli-Color liner that was used to do the hard top interior color mod? I might have to buy a case of that stuff.
