no lift on 35's
Old Apr 2, 2012 | 12:16 PM
  #81
NJBlackBetty's Avatar
I think those tires measure low 34 inch. That's what I've gathered on this forum, depending on what PSI you run.
Old Apr 2, 2012 | 12:23 PM
  #82
hombredelassrtas's Avatar
subbed. looking into 35's and the least lift possible (want to avoid replacing the front DS). looking at 1" leveling or 2.5" BB. I do not rock climb but do a good bit off off roading, trail riding and mudding. Not a whole lot of articulation needed just when riding on edges of mud buggy grooves. Also do not plan to get rid of or cut the stock fender flares.
Suggestions?
Old Apr 2, 2012 | 12:36 PM
  #83
westchester's Avatar
Suggestions?
No need to replace the driveshaft with a 2.5" lift, and it is a terrific sized lift with 35s for both daily driving and all off-roading.
Old Apr 2, 2012 | 12:52 PM
  #84
MrDillClinton's Avatar
Originally Posted by NJBlackBetty
Bump for my ? Could I run Bushwackers w Nitto Trail 295/70R18's? I may ditch the TF 2.5 lift. Used as a DD and on the beach a few times a year.
Can't say I've seen this exact combo, but running flat flares on anything smaller than a true 35x12.50 will cause the tires to look tiny. Flat flares and over +3" of lift starts to make even 35x12.50's look small. Not saying it would look bad, but if you ever wanted to add a lift too, you may regret it after the install.
Old Apr 2, 2012 | 01:24 PM
  #85
revvinkevin's Avatar
The only thing that will happen is your air dam will rub when you turn. It is easy to trim so it doesn't rub. I have 315/70-17 tires, no lift and bushwhackers and I'm good.
Old Apr 2, 2012 | 01:59 PM
  #86
G DIESEL's Avatar
I'll be joining the club by the end of the week, just ordered from Discount Tire Direct 17x9's -12mm offset with 315-70-17 Duratracs. I only plan to trim front fenders and front bumper, front spacer. Most of my wheeling is on the sand.
Old Apr 2, 2012 | 03:15 PM
  #87
You're gonna trim the Sahara fenders!???
Old Apr 2, 2012 | 03:31 PM
  #88
MotiCross's Avatar
Has anyone from this thread gone offroading? just wondering cause it looks as some would rub when going over a speed bump...
Old Apr 2, 2012 | 09:48 PM
  #89
SOCAL-JK's Avatar
Just installed these 35's on Sat. What psi would you guys recommend for daily to & from work commuting?
Old Apr 3, 2012 | 03:26 AM
  #90
soxkid's Avatar
same psi you ran your stock tires at... i run 32-35 depending on the trip
