Photos of Stock 18 sahara no lift with 33 tires
Old Sep 2, 2010 | 02:50 PM
  #31
Matador's Avatar
Ok....found some pics......Stock 18's with 33" Duratracs.....this was before the Spidertrax spacers and before leveling kit.
ID:	86045Click image for larger version
ID:	86046Click image for larger version
ID:	86048Click image for larger version
ID:	86049Click image for larger version
Old Sep 3, 2010 | 03:47 AM
  #32
swpierson's Avatar
How was it without/before the spacers? Was it rubbing and where did it rub? This is the tire size I am looking at but if I can avoid spacers I would like to.
Old Sep 3, 2010 | 04:04 AM
  #33
Matador's Avatar
It was rubbing on the air dam until I notched it out then later removed it all together....if I can remember correctly it also rubbed slightly on the sway bar links.....but that was only when I had the wheel completely cranked! I heard you can adjust your steering stops to eliminate this...I just went with the wheel spacers as it widened the stance and made it look nicer.
Old Sep 3, 2010 | 05:17 AM
  #34
Bone206's Avatar
I second that. I have the same tires and was rubbing on the sway bar at full turn and flex. The wheel spacers really improve the look and stance, and there is no rubbing that way too. Win win!
Old Sep 3, 2010 | 05:34 AM
  #35
highergr0und's Avatar
Here's mine..... 275/70/18 duratracs, stock suspension, no spacers. I get rubbing at full lock. I keep meaning to adjust the steering stops, but I've only rubbed once on a tight turn into a parking spot in the past few months. I'm probably just gonna hold out a while longer and get some spidertrax and a leveling kit.
Here's a before with the stock tires....
And after.....
Old Sep 3, 2010 | 08:07 AM
  #36
itsajeepthing's Avatar
Has anyone gone 275/65/18 which gy does make in a duratrac...
Old Sep 3, 2010 | 08:46 AM
  #37
jmoschgat's Avatar
Old Aug 1, 2014 | 02:48 PM
  #38
skinner21's Avatar
Im thinking about getting 33s with the stock sahara rims but I'm not sure if it will rub or not
Old Oct 20, 2014 | 05:09 AM
  #39
emailj's Avatar
Attachment 86045Attachment 86046Attachment 86048Attachment 86049Attachment 86050
Are these 275/70/18? I am looking to do the same with my Jeep.
