Side-mount Jerry Can Carriers for the JK
Old Apr 23, 2016 | 06:54 AM
  #241
jscherb's Avatar
A couple of photos someone posted on another forum, this person installed the side mounts for his Rotopax containers...
Old Apr 23, 2016 | 04:39 PM
  #242
jeepmojo's Avatar
Default looks great
What is needed if you wanted to change from can holder to a roto pax style ? Not that im going to but nice to know how .
seeing i have the holder and back plate frame , Is it just a matter of buying some type of roto pax adapter and undo the holder and mount it to the frame back plate ?
and didnt i read the can holder will hold 2 rotopax in the holder instead of 1 jerry can ?
Old Apr 23, 2016 | 06:10 PM
  #243
jscherb's Avatar
You remove the jerry can tray from the base and replace it with a mount from Rotopax. For a second container, Rotopax sells extensions for the mount. It's all here: https://rotopax.com/Mounting-Hardware/.
The side mount base has the necessary holes for the Rotopax mount.
The mount:
and the extension:
Old Apr 23, 2016 | 07:24 PM
  #244
jeepmojo's Avatar
Default thanks
wasnt exactly sure !
Old Apr 26, 2016 | 06:46 PM
  #245
JDaPP's Avatar
Thought I would share my weekend project. I found that the universal tray portion was a little too big in the garage here in California and I use them as my carriers for my rampage storage cans when camping. I took them on and off for awhile but as we approach camping season I wanted a more permanent solution. I used the Crown Jerry can holder and mounted it to the side mount panel. It sticks up a little bit, but good enough for my solution.
Old Apr 26, 2016 | 06:55 PM
  #246
JDaPP's Avatar
With Jerry can
Old Apr 29, 2016 | 09:59 PM
  #247
Erok's Avatar
A couple of action shots of the carrier on my Jeep.
ID:	645466Click image for larger version
And my extra bump stops. This seems to have solved the problem (and I didn't need to add four, I could have just added the bottom two).
Old Apr 30, 2016 | 07:22 PM
  #248
jeepmojo's Avatar
Default Looks Great on there
Totally love the look of the side mount jerry can vs The mounts on rear of jeeps , gives it a custom look and also a useful
Modification . nice photos
Old May 12, 2016 | 04:25 PM
  #249
jscherb's Avatar
Today I was at a military vehicle show and swap meet and spotted this side mount on an M37. Same location as the JK side mount, although the JK side mount doesn't need to be bolted through the fender or braced on the fender flare like this one is .
Old May 17, 2016 | 07:06 AM
  #250
Cascade Wanderer's Avatar
Veteran: Marine Corp
Have only mounted the passenger side so far. Works great for carrying an extra 5 gallons of fuel. No problems!
Have the driver's side mount and another Jerry can, but... I think for my trips this summer, I'll carry 5 gallons of fuel, and another 5 gallons of water on the driver's side, rather than even more extra fuel. Why not?
I like where it puts the weight on my two-door, between the axles, instead of hanging off the back of the Jeep.
CW
