Old Oct 18, 2013 | 02:38 PM
  #35861
kmrtnsn's Avatar
EVO Skid plates are now installed. A two hour job in a home garage, working alone. I painted them red because,...... well just because.
Old Oct 18, 2013 | 02:52 PM
  #35862
bmaloy32's Avatar
Vet Army
Default Knuckles Off Road (KOR) front and rear bumpers and Rigid Ind
Picked up my KOR bumpers this past weekend and got them installed throughout the week. I also put a set of Rigid Duallys in the front and rear and Rotopax system with the backplate from KOR. Still have to install the tire carrier and Warn Zeon 8.
Lift, wheels and tires in the future...Click image for larger version
ID:	506021Click image for larger version
Old Oct 18, 2013 | 03:14 PM
  #35863
Bubbacon's Avatar
Replaced my wire winch line with 100' rope, viking safety thimble, and poison spyder brushed aluminum fairlead.
Old Oct 18, 2013 | 06:07 PM
  #35864
GoinCamando's Avatar
Originally Posted by Pubdraft
Onboard air and water. Water held in stock bumper with RV water pump mounted under. Q Industries MV50 Air Compressor with 2.5 Gallon tank mounted on rollbar in cargo area. Removed spring from rear headrests so they stay down for better rear visibility. Fire ext., axe, shovel, and air comp. all mounted in cargo area. Axe and shovel mounted on "L" brackets using hardtop bolts. Panel on side for air and water made of sheet steel from Home Depot. I painted it w/ rust proofing paint and then Plasti Dip'd it, rubber mat under to help seal against body. Vinyl stickers came from Moyer Custom Vinyl Decals. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=506006"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=506007"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=506008"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=506009"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=506010"/>
That's a really great setup for the air tank. Think I'll steel it. LoL
Old Oct 18, 2013 | 08:33 PM
  #35865
BRUT4CE's Avatar
Former Member
Got under the jeep and noticed the lower control arms in rear were bent from the last run...
So I've got 2 sets of stockers and not ready to 3/4 link the jeep till I do the d60 14 bolt so beefing up a set was the perfect plan for the problem....I might make a set of arms with metalcloak joints to pass the time till I link but these are now stout and can be hammered Into stuff.
Took a piece of 120 wall 1.5 Dom and cut it length wise. Took another set of rear lowers cleaned em up and overlayed it welded it up and good to go play in the rocks....
Old Oct 18, 2013 | 09:40 PM
  #35866
palehorse's Avatar
Homemade control arm?! Epic!
Old Oct 19, 2013 | 04:58 AM
  #35867
Jersey_Devil's Avatar
So I've got 2 sets of stockers and not ready to link the jeep till I do the d60 14 bolt so beefing up a set was the perfect plan for the problem....I might make a set of arms with metalcloak joints to pass the time till I link but these are now stout and can be hammered Into stuff.
Took a piece of 120 wall 1.5 Dom and cut it length wise. Took another set of rear lowers cleaned em up and overplayed it welded it up and good to go plavy in the rocks....
That's definitely cool!
Sent from my obama monitoring device
Old Oct 19, 2013 | 05:16 AM
  #35868
GreenJK07's Avatar
I've got a very similar air set up. Works great! Same pump and tank.
Old Oct 19, 2013 | 06:45 AM
  #35869
JS1122's Avatar
Smittybilt src stinger and drake hood latches
Old Oct 19, 2013 | 09:10 AM
  #35870
RealJK's Avatar
Attachment 506006Attachment 506007Attachment 506008Attachment 506009Attachment 506010
Really nice work! Did you rotate the head of the compressor?
Sent from my SM-N900T
