Old Jun 17, 2014 | 10:31 AM
  #40081
BlackRockBurner's Avatar
Originally Posted by jkwilly14
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=560263"/>
That's what I don't understand: the inside looks fine. It's almost like the frame has shifted. Everything is in all the holes it's suppose to be. I'm just at a loss
Check and confirm the folding tab on drivers panel is up and flush. Is anything obstructing the rubber seal or interfering with the panel to lay flush?
Old Jun 17, 2014 | 11:44 AM
  #40082
JKMedicPA's Avatar
Originally Posted by svk8
Finally got it some lift plus installed my poison spyder diff covers
Anyone know what top and screen combo or what top svk8 is running for that soft top?
Old Jun 17, 2014 | 02:58 PM
  #40083
Whitejk13's Avatar
Got my trucklite headlights... They look sick. Also ordered anti flicker adapters.. Well adapter... For some reason I thought they'd come in a pair... So I have to order another one and I'll put them in this weekend
Old Jun 17, 2014 | 04:00 PM
  #40084
Bubbacon's Avatar
Heres a pick of all the vents installed for a few of you that have asked.
Tonight, metal brushed the rust spots off the front bumper and added 4 coats of fresh paint (rustoleum high heat enamel flat black)
Old Jun 17, 2014 | 04:07 PM
  #40085
lone*krwler's Avatar
I installed a Uniden 510XL CB radio with a 3' firestik antenna, and also painted the AC vent rings.
ID:	560322   Click image for larger version
ID:	560323   Click image for larger version
Old Jun 17, 2014 | 04:22 PM
  #40086
ACLeeJK's Avatar
Look up Bestop duster deck cover.....and the back window I think is called a windjammer.
Old Jun 17, 2014 | 05:22 PM
  #40087
zstairlessone's Avatar
So we finally took the top of for the first time this weekend. Now the back doesn't align with the t tops. The jeep dealer tells me this is normal? Any suggestions or is this normal??
Not normal!
Old Jun 17, 2014 | 05:25 PM
  #40088
MPH233's Avatar
Had the same problem two weeks ago and had to order a second as well! Definitely noticed an improvement in the headlights with them.
Old Jun 17, 2014 | 05:38 PM
  #40089
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=560241"/>
I'm not sure how well you can see but here is a pic
No, your Freedom top piece is not on correctly, take it off and see if the pin is bent somehow.
Edit, didn't see the other responses, can you take a couple more pics showing the whole front two pieces and with the door open and the latches and screw thing off to see how it lines up?
Old Jun 17, 2014 | 05:51 PM
  #40090
PFTWHFTB's Avatar
Originally Posted by zstairlessone
No, your Freedom top piece is not on correctly, take it off and see if the pin is bent somehow. Edit, didn't see the other responses, can you take a couple more pics showing the whole front two pieces and with the door open and the latches and screw thing off to see how it lines up?
Here is the best idea. Go and find someone who will let you put their freedom tops on and see of it does the same thing. If it does, then something is wrong on your jeep or something set up on there. If not, then it's your tops are set up wrong or bent. Compare the two set ups and see what is different between the two. I'm betting something is just lined up wrong or bent, the pads are down on the freedom tops or you have them on wrong in a form or another. They are a pretty easy thing to put on and take off, but if one thing is wrong, it won't work.
