Old Feb 21, 2016 | 03:39 PM
  #45701
truax's Avatar
New wheels,tires,lift and tinted tail lights.
Old Feb 21, 2016 | 03:41 PM
  #45702
Robros's Avatar
New fenders and doors.
Old Feb 21, 2016 | 04:04 PM
  #45703
drtyrat30's Avatar
Got my Aries aluminum fenders mounted and led side marker light.
ID:	638428   Click image for larger version
Old Feb 21, 2016 | 04:15 PM
  #45704
2013JKRUBICON's Avatar
how was the install? How do you like fitting? I'm thinking about going with some Aluminum ones. Tell me what you think.
Old Feb 21, 2016 | 04:19 PM
  #45705
Monte417's Avatar
You got a closer pic of where you mounted that light
Old Feb 21, 2016 | 06:56 PM
  #45706
Baja JKU OllllllO's Avatar
Vet Army
What wheel/tire combo you running?
Old Feb 21, 2016 | 07:17 PM
  #45707
JKEmmert77's Avatar
Veteran: Navy
Here's what my last three weekends involved
Old Feb 21, 2016 | 08:06 PM
  #45708
drtyrat30's Avatar
I kept and trimmed the inner plastic fender support and on the front section there is a place for a push tab. So I drilled it out to fit the light and wired it into the factory plug. The light body is threaded with a nut so it fits perfect and tight.
ID:	638489   Click image for larger version
Old Feb 21, 2016 | 08:10 PM
  #45709
drtyrat30's Avatar
37/12.5-17 Mastercrafts MXT'S courser on ATX cornice 17x9
Old Feb 21, 2016 | 08:21 PM
  #45710
drtyrat30's Avatar
I thought the install was fairly easy. The quality seems real nice with the powder coat and the aluminum. I went ahead and ordered a Astro riv nut tool from Amazon with the fenders. I think for front and rear with the tool and led side lights it was around $700. The tool makes setting the nuts very easy and tight. The fenders all matched factory holes with only one extra hole to drill in the rear. I had to modify a couple washers to fit but nothing major. Probably a 3-5 hrs job if you take your time.
ID:	638492   Click image for larger version
ID:	638493   Click image for larger version
ID:	638494   Click image for larger version
