Old Jul 4, 2009 | 07:28 PM
  #6001
edwin907's Avatar
6" KC Slim Long Range mounted on Baja Designs 1.75" mounts.
Old Jul 4, 2009 | 08:08 PM
  #6002
kd5zwf's Avatar
Originally Posted by e0987c5t3
Your rig looks freakin' AWESOMEE!! She sure is real purty
It's your set-up that makes me regret getting the 4door
Thanks, its only 2 days old in that configuration. Just finished the winch install and tomorrow will put 2 lights on the bumper....that will be it for a while. I figured if I stayed with the basics I can't go wrong. There are many nice rims and bumpers out there, but for the money I think I did ok.
Old Jul 4, 2009 | 08:48 PM
  #6003
judas's Avatar
cleaned it finally, also got my new spare in and mounted.
not sure why they look way bigger mounted on the spare carrier...
oh thats because the tards sent me a 10" rim instead of the 8" i paid for. ORO plate holder/light will be here tuesday.
also removed all the stickers. as soon as someone will sell me some used 2dr rubi rails i'll put a project jk.com sticker on there.
and of course had to add a sticker with my motto on it.
Old Jul 5, 2009 | 08:24 AM
  #6004
meljr's Avatar
Default Installed Mopar Tow Vehicle Wiring Harness
Nothing too exciting here. This harness is designed to plug into a 7 pin connector
on a towing vehicle to make the JK's tail, brake and turn signals work when being
towed. It came with the absolute worst set of instructions I have ever seen, but I
managed to figure everything out and it works great without having to disconnect
the JK battery or pull any fuses. Literally, plug it in and tow.
What may be of more general interest to every one, is the relatively easy method
of getting a large electrical cable through the passenger side firewall. Since I was
going to trim my stock fenders anyway, I removed the passenger side fender and
liner for easy access to the passenger firewall. There is a pad of insulation on the
engine side of the firewall that is held on by a knob that can be removed by hand
to expose the sheet metal. I removed the two 13mm plastic nut/washers that hold
the carpet down in the passenger foot well, pulled back the carpet and drilled a
1-1/8" hole through the very thin sheet metal next to one of the studs. There is
plenty of room to drill holes in this area. A standard grommet and some RTV seal
the hole and with the insulation put back, you would think it was factory.
The hole:
-meljr
Old Jul 5, 2009 | 06:13 PM
  #6005
ConroeJK's Avatar
Default Installed Slimlites on new XHD
Old Jul 6, 2009 | 04:39 AM
  #6006
Machine154's Avatar
New LOD bumper and Warn XD9000i winch.
Old Jul 6, 2009 | 03:55 PM
  #6007
Mike De's Avatar
Just changed diff oil to royal purple after the 500 mile brake in from re-gearing.
Old Jul 6, 2009 | 10:09 PM
  #6008
08jk4door's Avatar
well lets see i put on 12" king coil over with the outlaw bolt on kit je reel drive shaft 5:13 gears front and rear evo c2 gussets and made a trackbar and upper control are support brace and ordered some rock krawler lower control arms and i installed a jks adjustable track bar
Old Jul 7, 2009 | 06:06 AM
  #6009
JKBully's Avatar
THAT'S IT?????!!!!!!!!! Get to work!
Awesome work!
Old Jul 7, 2009 | 07:13 AM
  #6010
edwin907's Avatar
Remounted the lights to get rid of headlight glare (they were too high), installed a Teraflex SS, Flashpaq, and the AEM intake.
Runs like a mad SOB now!
