Old Nov 14, 2009 | 11:17 AM
  #7071
SgtMikey's Avatar
Installed a Tuffy rear security drawer that I picked up used..... Mikey
Old Nov 14, 2009 | 05:22 PM
  #7072
jeepmedic's Avatar
Ordered and early Xmas gift for myself....Smittybilt XRC 10 Winch
Old Nov 14, 2009 | 05:56 PM
  #7073
ThrashN's Avatar
I've done the following:
Mounted my Garmin and my Sirius radio, both were hotwired to the switched power outlet and all wires/cables hidden.
Put my Quadratec Ultimate Floor Liners in and added a Daystar Upper Dash Panel.
Thanks to the write up form I got the following done:
Grill mod
Mounted garage door opener behind the window pillar trim
My cruise control should be here Monday, so everyone can guess what I'm doing Monday after work.
Old Nov 14, 2009 | 06:01 PM
  #7074
JLS1983's Avatar
Fixed my hood fluttering by installing '09 hood latches!
Old Nov 14, 2009 | 07:02 PM
  #7075
ulev1st's Avatar
Installed the River Raider Crusher Corners and ORO Lites.
Old Nov 14, 2009 | 07:32 PM
  #7076
Suffolk JK's Avatar
Installed my OR FAB sport cage with floor tie-ins.
Old Nov 15, 2009 | 02:18 AM
  #7077
zook's Avatar
You hope you fixed it. I installed the 09 latches and it didn't fix the problem. I took the spring out. That fixed it. Good luck anyway.
Old Nov 15, 2009 | 03:49 AM
  #7078
Rzrbck's Avatar
installed the cooltech tow harness kit for flat towing
Old Nov 15, 2009 | 07:49 AM
  #7079
adamisadam's Avatar
I have a VERY early production `09. I had hood flutter. I bought the TSB / recall latches from the dealer and it fixed the bounce. (My model was not part of the recall!). I THEN removed the spring for good measure. But even with the spring, the fix worked.
Old Nov 15, 2009 | 07:53 AM
  #7080
Suffolk JK's Avatar
Finally got the OR-FAB cage pictures uploaded. Damn weather these past few days.
Fitment is damn near perfect. I forgot to fully trim the passenger side plastic on the upper dash so it sticks out a little past the dash, but I don't care since it doesn't interfere with anything. Boxes came fully sprayed in foam, but you do have to rip everything apart to get to all the parts. Powdecoating was very very nice, although did knick and scrape a few times here and there getting the cage in. SOLID! All brackets, bolts, and welding are SOLID. This cage isn't going anywhere. Still need to find a way to get the GPS bracket on there and Aux. CB speaker bracket on there. Floor mounts are THICK.
BTW, you DON'T need to assemble everything as one unit and drop it in. We tried that, SUCH A PITA to get in. Slid BOTH sides down the dash, THEN connected cross tubes. There's enough give of the dash to slide them in. Took about 7 hours between my friend and I to get in. All in all, a GREAT cage.
