Old Aug 5, 2010 | 09:05 AM
  #9491
79cj7's Avatar
Originally Posted by jinx667
I have been eyeballing that setup. How hard was the install?
It was super-easy! The instructions are very explicit, with color pictures. The only way you can screw it up is if you can't understand English. The hardest part was convincing myself that I needed to drill a hole on a one-month-old plastic housing. But all went well in spite of my insecurity. The only deviation I made is to put a thin washer between the bracket and the inside of the plastic housing. Without the washer, the housing didn't sit flush against the body. But that could have been due to the drilled hole location. If it's off a couple thousandths, the housing might be affected. The mount was a little pricey for my budget, but I couldn't come up with a better way. I didn't want to mount the antenna on the spare tire bracket, because I don't want to flex the coax every time I open the tailgate, and I didn't want to drill into the body. Give it a try!
Mark
Old Aug 5, 2010 | 09:37 AM
  #9492
Shoup's Avatar
It's very easy.
Old Aug 5, 2010 | 09:42 AM
  #9493
donnie's Avatar
From: Simi Valley, Ca., Taylorsville, Ut. and places in between
FWIW, Iv had the Ultra on mine for about six months and love it.
Got it with the four foot Firestik and it bumps the tail light housing once in a while but otherwise its great.
Only thing I wish is it was out far enough to install a spring for the antenna.
Hope this helps.
Old Aug 5, 2010 | 11:18 AM
  #9494
jinx667's Avatar
I think I will order the kit and give it a shot.
Old Aug 5, 2010 | 11:27 AM
  #9495
donnie's Avatar
FWIW, here s how it looks on mine.
[IMG][/IMG]
Old Aug 5, 2010 | 11:29 AM
  #9496
jinx667's Avatar
That will be perfect. Did the kit come with a QD for the antenna? If not I will get that too so I can take it off to fit in the garage.
Old Aug 5, 2010 | 11:44 AM
  #9497
79cj7's Avatar
No QD, you gotta pay extra for that.
Old Aug 5, 2010 | 11:45 AM
  #9498
Danny4652's Avatar
Default RC 2.5 inch coil lift.
Just got it back from the dealer after they installed a 2.5 inch Rough Country coil suspension lift with 2.2 shocks. It rides better than I anticipated and no squeaks. Wheels spacers are here and 315 70R17 will be here tomorrow!
Old Aug 5, 2010 | 11:51 AM
  #9499
jkclay's Avatar
Just finished a Pro-Comp Stage 2 4" short arm lift...looks good and rides great. Gonna test it out off road next weekend.
Old Aug 5, 2010 | 11:56 AM
  #9500
taher2.1's Avatar
Replaced original battery with Optima Yellow
