Chrysler Recalls 300K Wranglers for Brake Fiuld Leak
Old Jul 12, 2010 | 07:17 AM
  #131
Converted's Avatar
I was installing my lift over the weekend and noticed that the left front inner fender liner had indeed rubbed a flat spot on the rear brake line that is routed on the frame at that location.
I slit a 3" long piece of 1/4" fuel line and put it over the brake line so it would not get worse.
I called the dealer this morning and got the same "that is just a newspaper story" "there is no Brake line recall for your vehicle".
I called Chrysler and got the same from the guy on the phone. "If you are worried about it you should pay to have it inspected and repaired if needed and if there is a recall you will be reimbersed for the expense."
I asked to have it escalated. Someone is supposed to call, we'll see.
Taking it in and paying for it may actually be the best option. I predict a nationwide back order for that section of steel brake line shortly.
Old Jul 12, 2010 | 08:12 AM
  #132
wmcvey's Avatar
You could also just cut a notch in the liner above the brake line.
Old Jul 12, 2010 | 08:18 AM
  #133
mwebb's Avatar
i saw some rubbing marks on mine and just bent them out of the way
Old Jul 12, 2010 | 11:21 AM
  #134
hawkspi's Avatar
Default recall
my dealer fixed my trans fluid overheat problem but has not heard of the brake line problem.
Old Jul 12, 2010 | 11:51 AM
  #135
AZBang's Avatar
What did they do to fix it?
Old Jul 12, 2010 | 02:49 PM
  #136
hawkspi's Avatar
Default recall
made it so an idiot light comes on and tells you you are on fire.
Old Jul 12, 2010 | 02:53 PM
  #137
AZBang's Avatar
That's what I thought. Not much of a fix.
Old Jul 14, 2010 | 08:20 PM
  #138
KhmerWrangler's Avatar
I brought in my 2010 Jeep Wrangler to my dealer for an oil change and I asked them about recall, they dint seem to know anything. I asked them to check and they said there is no recall. Is this recall universal for all 2010 Wrangler or just for some as I don't get any letter from Chrysler either. Is there any way to find out?
Old Jul 15, 2010 | 08:28 AM
  #139
wmcvey's Avatar
Many times recalls are make public and also are on the NHTSA.GOV web site long before the manufacture issues the recall to the owners and even their dealers. Here is a summary:
"NHTSA CAMPAIGN ID Number: 10V236000
Summary:
CHRYSLER IS RECALLING CERTAIN MODEL YEAR 2006 THROUGH 2010 JEEP WRANGLER LEFT AND RIGHT HAND DRIVE PASSENGER VEHICLES MANUFACTURED FROM MAY 15, 2006 THROUGH APRIL 22, 2010. THERE MAY BE CONTACT BETWEEN THE RIGHT AND LEFT FRONT INNER FENDER LINERS AND THE RIGHT FRONT AND LEFT REAR BRAKE TUBES WHICH COULD CAUSE WEAR OF THE TUBES CAUSING A BRAKE FLUID LEAK.
Consequence:
A BRAKE FLUID LEAK CAN CAUSE PARTIAL LOSS OF SERVICE BRAKES AT THE AFFECTED WHEEL INCREASING THE RISK OF A CRASH.
Remedy:
CHRYSLER WILL NOTIFY OWNERS AND DEALERS WILL REPAIR THE VEHICLES FREE OF CHARGE. OWNERS MAY CONTACT CHRYSLER TOLL-FREE AT 1-800-853-1403.
Notes:
CHRYSLER'S RECALL CAMPAIGN NUMBER IS K13. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV . "
Old Jul 16, 2010 | 07:25 PM
  #140
Oh thanks for the text. It might be a good idea for me to call the number below to find out.
