Which detachable air compressor?
Old 12-14-2014, 05:26 AM
trouty33's Avatar
Default Which detachable air compressor?
I am looking at buying a 12v air compressor so I can air up after running trails. I don't want to keep it mounted to the jeep because I would have good use for it with other vehicles also. So the alligator clip style is what I am looking for. I'm not worried about it being fast just needs to do the job and want to spend $75-100.
What options are you all using? Thanks for all the help.
Old 12-14-2014, 05:48 AM
NVW-SSV's Avatar
I've been really happy with this one. Used it half a dozen times. Gets hot but takes 3 minutes per tire from 14psi to 32 psi.
Good price too. Also have 1050 model which has a few attachments.
Old 12-14-2014, 06:26 AM
Clark Collins's Avatar
I am using an MV50 also and am very pleased with it. I've pumped up 8 35s with it before. You need to turn it off between tires or it will build up enough pressure to pop the hose. It is a real bugger to get back connected again. I've had mine for over 2 years. They are less than $60 on Amazon.
Old 12-14-2014, 08:48 AM
Tooadvanced's Avatar
Been using my harbor freight one for 2 years. Our trail boss has had his for 5 or 6 years no problems. Only complaint is of someone else doesn't have one it will overheat after about 6 tires from 10-11 psi to 30-35psi. 2 or 3 minute break and good to go
Old 12-16-2014, 01:48 PM
trouty33's Avatar
Originally Posted by NVW-SSV
I've been really happy with this one. Used it half a dozen times. Gets hot but takes 3 minutes per tire from 14psi to 32 psi. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=587826"/> Good price too. Also have 1050 model which has a few attachments.
Thanks I've looked at it and looks decent!
I've considered the one from Harbor Freight but not a big fan of their stuff specially since the price isn't any better than this one.
Anyone else with other options??
Old 12-16-2014, 02:18 PM
jk_sea's Avatar
Attachment 587826
I've had huge quality issues with mine. Bad/loose soldering and wire connections, leaking air hose, cheap carrying case (plastic clip broke), and the pump gets hot and rests on its own schedule. I bought it thinking it would be the perfect setup (draw straight from battery, long, coil-up air hose, gage on the pump and not inline, etc), but it turned out to be junk!!!
I've read similar reviews on Amazon and I am not alone with my experience.
I don't know what else to recommend, as I'm in the market for a new one as well!!
Old 12-16-2014, 06:16 PM
RoysRig's Avatar
I did this too, but bought the warranty knowing I would probably need it. After about a dozen uses the ball bearings in side cut loose and used the warranty. What they don't tell you is that it's a one time use warranty. Once they replace the item you have to buy another warranty. Said piss on that and if it breaks again I would buy an ARB for under the hood. So needless to say I now have a ARB.
Oh and if you do buy the warranty be sure to keep the receipt, I did, and when I went to make the claim it wasn't in their system, they tried to talk their way out of replacing it, but I said I had my receipt for the replacement warranty and one way or another they were going to replace it.
Old 12-17-2014, 02:54 PM
trouty33's Avatar
Anyone else with any suggestions??
Old 12-17-2014, 03:29 PM
Billbikes's Avatar
It looks like the same one I'm using. Got it at pep boys a few years ago and has served me well.
Old 12-17-2014, 03:30 PM
Billbikes's Avatar
If you can afford it I really like the Vair compressors.
Quick Reply: Which detachable air compressor?
