Will it work guys?
Old Jan 9, 2013 | 03:46 PM
Ashleyjk's Avatar
Default Will it work guys?
Can I run 265/70 or 275/70's on a 17x9 wheel ? Everything is stock except for the wheels. 17x9 4.5 bs and -12 off set.
Thought a 285/70 would cause rubbing or kill power?
Old Jan 9, 2013 | 04:05 PM
Tonka_yellow's Avatar
I am running a 285/75r16 on a wheel with 4.00 inch backspacing. Your good man. As far as power I can tell but it ain't that bad
Old Jan 9, 2013 | 04:08 PM
Jonathan_JK's Avatar
I got a buddy who is running 265's on stock 17" rims no spacers stock BS. I'v been wheeling with him no problems at all not even when disco. I think you will be good.
Old Jan 9, 2013 | 04:13 PM
Ashleyjk's Avatar
Well I really like the wheels that are 17x9 but just wasn't sure if a 265 or 275 would fit ok on that width wheel. I air down on the beach and usually take some other girls along so was afraid the 285 would rub with all our stuff and people aboard?
Old Jan 10, 2013 | 07:07 AM
yo_marc's Avatar
I'm running 265-70-18's, if that helps?
They work great. No rubbing lock to lock.
Edit: Sorry, I overlooked the part about aftermarket wheels. The above is on a stock rim.
Old Jan 10, 2013 | 07:10 AM
JKJA10's Avatar
My stock rims are either 17x7.5 or 17x8 any way the tires that are on them are 285/70R17. But you will need 1.5" spacers
Old Jan 10, 2013 | 12:32 PM
madmike232's Avatar
I have ran 285 75 17s on stock wheels only a little rub full wheel lock on that plastic skid plate from factory can be notched out easy
Old Jan 10, 2013 | 01:29 PM
CerOf's Avatar
You'll be fine. These are 305/65R17 with only a leveling kit.
Rims are 17x9 with basically 4.5" BS
Old Jan 10, 2013 | 02:13 PM
patricks99's Avatar
Veteran: Marine Corp
I'm running 285/75/17 BFG MT KM2 on stock rubi wheels and 1.5in spacers (just to be sure of no rubbing and I like the tire pushed out a little bit)
