Trails in Moab?
I'm headed to Moab for Labor Day (I'm assuming it'll be jam packed). Looking for some trail recommendations! I'm signed up on Badge of Honor and know that there are a number of Moab trails also on that app.
I've done some easy to moderate off road trails and my Jeep is stock. Looking for recommendations on some trails, as well as if there will be any jeepers out there that weekend willing to ride together!
Moab Jeep trails with gpx tracks - * * * * * Jeep the USA
Fins and things is a nice moderate trail. There are a lot of steep descents, and climbs, so make sure you air down so that you can get maximum traction. On the first half there is a Down, an immediate up, then a down again. If you handle that okay, you should be set with minimal dram for the rest of the trail.
Poison Spyder is a little tougher. There are some water falls that probably would not be for someone doing them, by themselves, for the first time. There are a few winch anchors on the trail on the steeper sections. There are some pretty challenging sections with pucker moments, as well. I found it tougher than Hells Revenge or Flat Iron Mesa, but that is just me. I don't know that I would feel comfortable taking a pure stock jeep on it, though I am sure that it could make it. You just have to be prepared for any associated damage that might happen.
Fins and things is a nice moderate trail. There are a lot of steep descents, and climbs, so make sure you air down so that you can get maximum traction. On the first half there is a Down, an immediate up, then a down again. If you handle that okay, you should be set with minimal dram for the rest of the trail. Poison Spyder is a little tougher. There are some water falls that probably would not be for someone doing them, by themselves, for the first time. There are a few winch anchors on the trail on the steeper sections. There are some pretty challenging sections with pucker moments, as well. I found it tougher than Hells Revenge or Flat Iron Mesa, but that is just me. I don't know that I would feel comfortable taking a pure stock jeep on it, though I am sure that it could make it. You just have to be prepared for any associated damage that might happen.
I air down to 12-14, have never slipped a tire. If you are concerned that you may slip a bead most people I ride with run 15.
I had Well's southern CO book on my recent trip. It was better than nothing but just bairly. He tried to cram too much stuff into that little book so the maps are so small they're nearly worthless. The maps also didn't show intersecting trails. I had a GPS app on my iPhone and .gpx tracks for all the trails and that saved me from getting lost. If you're interested I could give you the app name and where you can get the tracks for free.
Also I would give you a little advice here. I do appreciate the tips I got here on the threads that I posted asking about specific trails in CO before we went but I found that the locals underestimated the difficulty of some of the trails. I consider myself between a moderate and expert and do some fairly difficult trails here in OK, but while some indicated a trail was "just a gravel road", to me might be pretty scary. So consider that to a local or expert Jeeper a trail might be easy to them but be very hard for you.
Good point. What some people and areas consider a back road, might be considered a highly technical trail somewhere else. It also depends on experience for a particular type of four wheeling.
I consider Fins and Hells both to be relatively simple trails. Particularly without the major obstacles of Hells. I know others will freak out on them because of the climbs and descents.
Good point. What some people and areas consider a back road, might be considered a highly technical trail somewhere else. It also depends on experience for a particular type of four wheeling. I consider Fins and Hells both to be relatively simple trails. Particularly without the major obstacles of Hells. I know others will freak out on them because of the climbs and descents.
