Bofer84's Locker Mod Write-up
I think you have something wrong, on the stock application, the lights blink when you press the locker switch, and continue to blink until the lockers are able to engage. Once the lockers engage in a stock Rubi, the light stops blinking and goes on steady, to let you know your ready to go. If your lights have never gone solid when using the lockers in 4LO before this mod, you had something going wrong. Don't know if you can have the dealer diagnose it now with the mod tho. Sounds like an electrical gremlin only, since you've had your lockers working.
Bofer84's, thank you for the write up. 2nd easest mod completed. What a difference. Only change I made was to splice in farther down to hide under the battery box and use pin connectors on the ground. Hopefully this way stealerships will really have to look to see the mod. I have the lifetime power train and want it to keep it.
Only real question is there a way to turn off the esp long term? When using the lockers in high you have to hit the switch when you go to low the esp stays off but from low to high or retsrting after a stall it resets. Is there a way to add a toggle to the esp circuit that turn it off until you want it turned back on with out lossing other fuctions like antilock brakes?
the new switch will lock your locker when it is flipped "on" (without touching the oem switch). when the new switch is left in the "off" position, the oem switch functions to lock your locker normally.
