Bofer84's Locker Mod Write-up
Old Sep 5, 2007 | 01:53 PM
  #41
Rubidonn's Avatar
Originally Posted by RubiconToad
I think you have something wrong, on the stock application, the lights blink when you press the locker switch, and continue to blink until the lockers are able to engage. Once the lockers engage in a stock Rubi, the light stops blinking and goes on steady, to let you know your ready to go. If your lights have never gone solid when using the lockers in 4LO before this mod, you had something going wrong. Don't know if you can have the dealer diagnose it now with the mod tho. Sounds like an electrical gremlin only, since you've had your lockers working.
So here's the story... and you have come pretty close to hitting the nail on the head. I got under it today and jacked the rear end up and played around w/putting it in 4lo w/the factory switch turning on the lockers... as well as played around w/4hi and 2hi and 4lo w/my manual switches. In all cases, you can hear the relays turning on and the lockers are locking. Even though the lockers are locked (using the factory switch) in 4lo, the indicator light only blinks... never goes solid. When I use my manual switches, nothing at all on the dash comes on... but the lockers do lock. So I stopped by the shop that did my gear swap and talked to him... he said he has another Rubicon that is doing the same thing. He's thinking that the indicator switch probably needs to be shimmed out a touch. He believes when the disk around the locker moves when the locker engages and therefore moves the indicator swtich... that the indicator switch is not moving out fully... and therefore probably needs to be adjusted. He's gonna look into it more and I may stop by over there on Friday and he'll throw my Jeep on the rack and play around with the indicator switch a little (probably try and back it out a little from the pumpkin) to see if he can get the lights to stay on solid.
Old Sep 12, 2007 | 06:04 AM
  #42
roddogg's Avatar
Default Adding switch to turn off esp long term
Bofer84's, thank you for the write up. 2nd easest mod completed. What a difference. Only change I made was to splice in farther down to hide under the battery box and use pin connectors on the ground. Hopefully this way stealerships will really have to look to see the mod. I have the lifetime power train and want it to keep it.
Only real question is there a way to turn off the esp long term? When using the lockers in high you have to hit the switch when you go to low the esp stays off but from low to high or retsrting after a stall it resets. Is there a way to add a toggle to the esp circuit that turn it off until you want it turned back on with out lossing other fuctions like antilock brakes?
Old Sep 15, 2007 | 05:55 PM
  #43
choda's Avatar
so you only can do this locker mod on rubys not on the x if you have a x what do you need to do
Old Sep 15, 2007 | 06:54 PM
  #44
bofer84's Avatar
Is there a button to lock the rear locker on the X
Old Sep 16, 2007 | 04:41 AM
  #45
choda's Avatar
No buttons on a X to lock
Old Sep 16, 2007 | 07:43 AM
  #46
BLKRuby's Avatar
Is it possible to do this using the factory swithces on the Rubicon? I am sure it is, anybody tried?
Old Oct 9, 2007 | 01:13 PM
  #47
CarFanatic's Avatar
So when you do this mod, the stock button works, and the switch works?? I have an x with rear locker, and yes we have that same switch as the rubi.
Old Oct 9, 2007 | 02:40 PM
  #48
mcnaught6's Avatar
the new switch will lock your locker when it is flipped "on" (without touching the oem switch). when the new switch is left in the "off" position, the oem switch functions to lock your locker normally.
Old Oct 10, 2007 | 05:10 AM
  #49
CarFanatic's Avatar
gotcha. This should work on an x too then. I would think theres just one relay up there for the rear.
Old Oct 10, 2007 | 09:05 AM
  #50
naplesrubicon's Avatar
if this is the only way to do can i tap both wires and run them to one toggle switch??
thanks
