breather tubes extended
Yes, I meant to say that the green is tranny and white next to it is T-case.
the tranny breather isn't nearly as high up as the t-case one, but in same area (but on passenger side). Stupid, that it's not as high!
I got at mine from below. It comes out of the tranny very close to the dipstick tube. It's zip-tied in place. I got my hand on it and yanked it downward. First I got at the end and grabbed the green end entirely off (not just the cap), then I was able to pull the rubber hose downward, out of the zip ties. I was trying not to cut it anywhere. It was not easy, but I did it.
Then, I fed extra long new hosing down from above, mated the new to existing underneath, and worked it all back up by pulling from the top.
viola!
viola!
From: Hangin in the sunshine state....staging forum..
it doesnt show a breather for the manual in my service manual, however another member that I wheel with got water inside his tranny, they figured out it cam in thru the shifter area, there is a metal ring that holds the rubber boot onto the top of trans, well that metal ring has a foam "seal" under it but that doesnt seal it from water if you get stuck that deep, he took his off and put silicone around it to seal it better
Extending the breathers is not enough to keep water out of the diffs. You also need to reseal the covers. I had water up to the top of my tires, with extended breathers and when I checked the oil after my trip, there was water in the diffs.
That's interesting. Why do you suppose water got in if oil wasn't getting out?
Another member had the same problem and it ended when he replaced the diff covers. I don't know if the solution was the new corers or the new seals.
I don't buy that heating/cooling too fast. Air would come in through that breather hose before the vacuum effect actually sucks H2O through a sealed cover! Now, I do believe that the factory seal on the cover might be too thin. When I replaced my front cover, there was almost NO sealant in there. It was SUCH a thin layer of silicone, I was amazed! So maybe water got in simply because the seal wasn't good enough to withstand total submerging in water of the pumpkin. That's more pressure than either 1) the vacuum caused by heating/cooling of gear oil, or 2) the gravity only pressure of gear oil resting on the bottom of the diff cover (it's only partially filled, don't forget).
Along those lines: I put my Warn diff guard on the rear without removing and factory cover. So that means I only removed and reinstalled the bottom bolts. It now leaks a little. When I did the same thing on my last Jeep, I had no problems with leaking and I think the only difference is that this time it was the factory seal, and last time it was after I had serviced the rear a few times.
That reminds me, I gotta go home and change my rear diff fluid and re-seal it!
That's my $.02.
That's my $.02.
