Disable/Enable feature codes/sequences
Old May 8, 2015 | 04:32 AM
  #261
The Black Jeep's Avatar
Originally Posted by Sandypants
Any write ups on moding the e brake so DVD and navigation work in motion?
There isn't an e brake signal the can bus tells the stereo the vehicle is in motion the lockpick as mentioned above is the only way I know of to get dvd in motion it also has a long list of other features included
Old May 8, 2015 | 12:08 PM
  #262
Sandypants's Avatar
There tech said will not work with manual. Is that true.
Old May 8, 2015 | 02:02 PM
  #263
Monkeyfist's Avatar
[QUOTE=Grant.UNT;3009096]
Originally Posted by Dezertjeepin
I am starting this thread so that there is a central location for all the little tricks, codes, and sequences to our JK's.
Im not talking about the "Secret Stash" places and the bottle openers (even though I use the bottle openers on a regular basis). But I'm talking about actual features that were built into the JK's computer.
So you get the idea, I'll start with ones I have found over the years....
Turn seatbelt chime OFF COMPLETELY!!!
1. turn the ignition switch to the OFF position, and buckle your seat belt while sitting in the drivers seat.
2. turn the ignition key to the ACCESSORY/RUN position (engine does not need to be running), and wait for the seat belt warning light to turn off.
3. unbuckle and then re-buckle your seat belt at least three times within 10 seconds, ending with theseat belt buckled. then start the jeep.
4. turn the ignition key to the OFF position. A single chime will sound to signify that you have successfully completed the programming.
Next time you start the jeep, you’ll hear the initial fasten seat belt chimes, but the continuous chiming reminder will be turned off. the light in the dash will remain on, though.
finally, I got it. I didn't see on the other posts about this that you have to turn the car on at the end of step 3. I haven't tested it yet, but I did get the single chime after step 4. So, thanks for the write up. I assume it worked.
This makes me so very happy, thank you
Old May 9, 2015 | 11:41 PM
  #264
Sandypants's Avatar
I notice moving, stopped, in our out of gear my 13 rubies button, "click here to view movie", comes on no matter what if I just pull the ebrake one click.... no I'm not gonna drive around with my e brake engaged... so figured it was a ground or something
Old May 16, 2015 | 05:30 PM
  #265
3Fletch's Avatar
Subscribed
Old Feb 29, 2016 | 12:21 PM
  #266
vicaven's Avatar
Default Oil light indicator
Originally Posted by the_yeti
"change oil boogie"
do this to tur off the "change oil" message that scrolls across your od
1. Turn the key to the run position
2. Press the gas pedal 3 times (pressing all the way to the floor within 4 seconds)
3. Turn the key to the off position.
i beleive this just resets the computer to think that you have already changed your oil. Dont forget to change it either before or after you reset the oil life indicator.
Old Mar 3, 2016 | 04:26 AM
  #267
mrzw70's Avatar
subscribed
Old Mar 14, 2016 | 08:38 AM
  #268
zimm17's Avatar
Veteran: Navy
Originally Posted by mrzw70
subscribed
Why do people post in order to subscribe? Not required.
Old Mar 15, 2016 | 08:32 AM
  #269
BAJA TYM's Avatar
Attachment 640677
For many reasons... some possible guesses are...
1) it gives the thread a bump to the top.
2) to possibly give support to the OP.
3) they just don't know any better.
4) who knows...
Old May 18, 2016 | 08:38 PM
  #270
XPoser's Avatar
Default Lock rear door without the battery
Removed my battery to charge it, went to lock it back up and realized I couldn't. Live in a condo, and I don't know how to lock my JK. My front doors are locked, but I didn't see a way to lock the rear door. Anyone know how to manually lock the rear door?
