Front and rear Adjustable Track Bar Centering
Old Aug 31, 2008 | 04:06 AM
JulietKilo's Avatar
No, my steering was way off and a quck turn of the draglink and I was back in business. Its not hard at all.
Your esp may be going off cause your wheels are NOT in line due to the track bars and or the computer is sensing one tire spinning faster then the other and its out of spec with the factory settings due to the tire being pulled faster on one side with the track bar issues. Also if your steering is not perfectly centered this will happen every time.
Old Aug 31, 2008 | 10:36 AM
cgtweet's Avatar
Default re
Ok. I have centered the steering. Do you have to drive for awhile for it to go out?
Old Aug 31, 2008 | 12:35 PM
JulietKilo's Avatar
No it should go out immediately following the fix. Turn you Jeep on and off and drive it again, it should then go out. It will however stay on if you fixed it and did not restart the Jeep.
Old Aug 31, 2008 | 05:31 PM
cgtweet's Avatar
Default re
Thanks for the help. drove the jeep for about ten miles. When I restarted it, the light was out...:-)
Thanks for the write up and guidance.
Vince
Old Sep 1, 2008 | 04:00 PM
TxCop07's Avatar
Vet Army
good job.....
Old Sep 1, 2008 | 06:29 PM
JulietKilo's Avatar
Hey, anytime. We are all here to help!
Old Sep 1, 2008 | 06:43 PM
cgtweet's Avatar
Default re
Juliet Kilo's write up is great. The only thing I would add for beginners like me, is that the steering will be off even after the axles are centered.
Know that I have done it... it would be so easy next time...;-) I look ofrward to helping someone do theirs.
Old Dec 16, 2008 | 04:15 PM
If I don't immediately center my steering, will my esp light come/stay on?
Old Dec 16, 2008 | 04:32 PM
Rhino64's Avatar
It most likely is going to go and off until you recenter your wheel unless its really off. Just dive under there and get her done only takes five minutes.
